torque spec for the pump
Bryant Lanctot
PostPosted: Sat May 15, 2010 10:15 am    Post subject: torque spec for the pump Reply to specific post Reply with quote
I have already rebuilt the pump itself, but I need to know what the
Ford Factory torque spec for the hydraulic pump is to hold it all
together? My manual doesn"t say.
Also, what is the spec to bolt the pump back into the tractor?
1949 Ford 8N
Dean
PostPosted: Sat May 15, 2010 10:24 am    Post subject: Re: torque spec for the pump Reply to specific post Reply with quote
Bryant:
Torque the pump to differential case mounting bolts to 65 lgs./ft.
The torque spec for the chamber mounting bolts is not given in the FO-4 manual. The grade 8 fine thread bolts thread into the aluminum pump casting, so DO NOT spec to the recommended torque spec for grade 8 bolts/nuts as advised by at least one poster on another board. I use 35 lbs./ft.
Dean
Bryant Lanctot
PostPosted: Sat May 15, 2010 5:16 pm    Post subject: Re: torque spec for the pump Reply to specific post Reply with quote
Dean
Thank you. sorry I did not get back to you sooner.
Bryant
