pressure building up in fuel tank
farmchecker43
PostPosted: Sat Jun 12, 2010 3:26 pm    Post subject: pressure building up in fuel tank Reply to specific post Reply with quote
I have a 49 TO 20 & when you use it much the fuel builds up pressure in the tank , have tried a new gas cap but still does it the tank has been cleaned at a radiator shop & had a liner put in ( sprayed I think )
Marlowe
PostPosted: Sat Jun 12, 2010 6:31 pm    Post subject: Re: pressure building up in fuel tank Reply to specific post Reply with quote
just buy a vented cap. thats what they had new. when you replaced the cap did you ask for a vented one ?
Kevin OH
PostPosted: Sat Jun 12, 2010 7:35 pm    Post subject: Re: pressure building up in fuel tank Reply to specific post Reply with quote
i had preasure building up on my te20.the gas was boiling after you used it for awhile.i got some heat barrier material from napa and put it on the bottom of the gas tank.it helped on my te20 a lot
Fred Hart
PostPosted: Sun Jun 13, 2010 4:21 am    Post subject: Re: pressure building up in fuel tank Reply to specific post Reply with quote
as said before check and be sure you have a vented gas cap.
auto gas caps are not vented, someone may have installed a auto gas cap
my to35 has a metal shield under gas tank and its over the exhaust manifold. check with someone else who owns a tractor like yours that is not having the heat problem, see if your tractor has the same heat shielding as the tractor that does not have the heat problem.
maybe someone on forum will make a picture of their tractors heat shield.
need to get this problem fix as this could be a very serious safety problem.
mowr
PostPosted: Fri Jun 18, 2010 7:35 pm    Post subject: Re: pressure building up in fuel tank Reply to specific post Reply with quote
As others have said, "will-fit" gas caps designed for modern cars can be deadly when installed on tractors that were designed for fully vented gas caps (NO pressure/no vacuum). Check out some of the posts regarding free tractor gas caps from the tractor companies to help avoid the flash fires that happen when something lets go.
jfnewt
PostPosted: Sat Jun 26, 2010 6:19 pm    Post subject: Re: pressure building up in fuel tank Reply to specific post Reply with quote
http://www.flickr.com/photos/21902222@N07/4640072323/sizes/l/in/set-72157623639099423/ This is a link to pics from my TO35 heat shield
Untitled URL Link
