TO 35 Steering box adjustment
Larry Gish
PostPosted: Tue Jul 20, 2010 5:24 am    Post subject: TO 35 Steering box adjustment Reply to specific post Reply with quote
I just aquired a TO 35 with about 1/8 ~ 1/4 turn play in the steering gear box. I tried tighting up the two adjuster nuts on each side of the box and nothing happened other than the force to turn the steering wheel got a little harder. The play is still there. Is there some trick to adjusting this. Thanks in advance.
phil(va)
PostPosted: Tue Jul 20, 2010 7:22 am    Post subject: Re: TO 35 Steering box adjustment Reply to specific post Reply with quote
Do you know the play is in the box and not in the tie rod / connecting rod joints?
Larry Gish
PostPosted: Tue Jul 20, 2010 7:47 am    Post subject: Re: TO 35 Steering box adjustment Reply to specific post Reply with quote
Yes, I have checked all the tie rods and linkage. It is tight. I replaced all the loose ones. You can watch the steering arms that come out of the box and they do not move until the play is out. I am starting to think the adjustments are stuck. Trying to find a way to check the oil level in the box. I have always had Olivers, first Harry Ferguson. Thanks
Fred Hart
PostPosted: Tue Jul 20, 2010 11:34 am    Post subject: Re: TO 35 Steering box adjustment Reply to specific post Reply with quote
take battery out and oil fill screw should be under battery. on top of steering gear box
if it is empty then fill with john deere corn head grease as the seals are gone and regular gear box oil will just run out.
adjust:
i jack up front of my tractor get front wheels off ground. loosen large nut then screw in adjusting screw about 1/4 turn, then do same to other side. if you get them too tight you can feel the gears bind when you turn far right/left.
if the gears bind when turned far l/r but in the center (wheels straight ahead) you still have the loose play, then most probably the gears are worn in the center from lack of oil.
(must back off adj until you have little to no binding when wheels are turned full r/l.
replacement gear box is very high
just fill gearbox with corn head oil and drive it. in the dirt a little loose play is something you can learn to live with. Remember The old tractor is about 50+ years old.
new iron cost big bucks.
Fred Martin
PostPosted: Tue Jul 20, 2010 12:01 pm    Post subject: Re: TO 35 Steering box adjustment Reply to specific post Reply with quote
I was just telling in a post this morning about a TO 20 I have that apparently it shimmyed on the road and someone adjusted the tow in so it would behave itself...but, more tire wear.
Not much to do except replace the segment gears and the gear on the end of the steering shaft. ohfred
