Case 600B over heating can the thermostat be removed easy
Leonard Shaner
PostPosted: Tue Aug 10, 2010 4:16 pm    Post subject: Case 600B over heating can the thermostat be removed easy Reply to specific post Reply with quote
Can someone help me with A CASE 600B how hard is it to get to the thermostat. I have a over heatng problem and need to move the machine while I find some parts.
Eldo case
PostPosted: Thu Aug 12, 2010 8:41 am    Post subject: Re: Case 600B over heating can the thermostat be removed ... Reply to specific post Reply with quote
It is in the upper radiator hose if it has one. You sure that is the problem! Loose fan belt?
buickanddeere
PostPosted: Thu Aug 12, 2010 6:34 pm    Post subject: Re: Case 600B over heating can the thermostat be removed eas Reply to specific post Reply with quote
Leonard Shaner wrote:
(quoted from post at 20:16:25 08/10/10) Can someone help me with A CASE 600B how hard is it to get to the thermostat. I have a over heatng problem and need to move the machine while I find some parts.
How do you know the stat is the problem?
Taking out a working stat doesn't help. it's already wide open. Overheating is likely from a scaled rad and block from using tap water as coolant. Worn glazed fan belt which wears the pulleys. Lean mixture and/or late timing.
