Case 580CK Backhoe / Loader Brakes
Greenie727
PostPosted: Mon Aug 30, 2010 1:39 pm    Post subject: Case 580CK Backhoe / Loader Brakes Reply to specific post Reply with quote
I have a Case 580CK Diesel Backhoe /Loader manufactured in the early 70's. I have owned the unit for approximately 20 years for light homeowner use. Right now the left side brake will grab and lock the left tire with the slightest pedal pressure. The brake then has to be freed by reversing the direction of the tractor to unbind the brake. I have the service manual and I'd like to pull the brake cover off and check the Band and disc linings, balls, and return springs. Does anyone know for sure if the brake cover can be removed with the loader and backhoe mount plates on the rear axle? It looks like there is only about 1 1/2" to 2" of clearance to the side of the brake cover assembly. I do not want to remove the loader and backhoe and just wanted to know if it is possible to pull the left and right brake covers and remove the disc / band assembly with the loader and backhoe mounted and in place on the tractor? The right brake cover has the differential lock mounted on the center of the cover. Will this cover clear the loader mount plates also? Also any thoughts on what may have broken or caused the sudden locking of the left brake? Thanks in advance for any and all information on the above questions...
mEl
PostPosted: Tue Aug 31, 2010 3:08 am    Post subject: Re: Case 580CK Backhoe / Loader Brakes Reply to specific post Reply with quote
Sounds like you need a rebuild on the brake system, new discs, bands springs and balls, clean up the ball sockets reassemble dry. if any sign of oil in the housing you should reseal the shaft. It was customary to cut a notch out of the loader frame to allow clearance for the bolt it makes it much easier but its and easy job to replace the brakes. mEl
Greenie727
PostPosted: Tue Aug 31, 2010 3:56 pm    Post subject: Re: Case 580CK Backhoe / Loader Brakes Reply to specific post Reply with quote
Thanks mEL, I'll check for the cutout notch to remove the bolts. Hopefully the cover will clear the mount plates once the bolts are removed...Ed
