pto clutch repair on 550 oliver tractor
dc11
PostPosted: Sat Sep 18, 2010 5:20 pm    Post subject: pto clutch repair on 550 oliver tractor Reply to specific post Reply with quote
Need to know huw to replacc clutch disc on 550 oliver tractor
Farmritch
PostPosted: Sat Sep 18, 2010 6:48 pm    Post subject: Re: pto clutch repair on 550 oliver tractor Reply to specific post Reply with quote
You will need to find a repair manual,
Split the tractor
And find a spanner type socket
Farmritch
dabot
PostPosted: Sun Sep 19, 2010 4:15 am    Post subject: Re: pto clutch repair on 550 oliver tractor Reply to specific post Reply with quote
Please be advised that there are two set screws holding the pack in place! It will save you a lot of time that I lost.
dc11
PostPosted: Sun Sep 19, 2010 2:54 pm    Post subject: Re: pto clutch repair on 550 oliver tractor Reply to specific post Reply with quote
Thanks. Did u have to split the tractor apart or can u replace them through the hole in the bottom of housing.
J. Schwiebert
PostPosted: Sun Sep 19, 2010 3:31 pm    Post subject: Re: pto clutch repair on 550 oliver tractor Reply to specific post Reply with quote
You need to make what in Oliver terms is called the "Z" split. q1uestions? J.
wmthrower
PostPosted: Wed Sep 22, 2010 3:42 am    Post subject: Re: pto clutch repair on 550 oliver tractor Reply to specific post Reply with quote
Its not too bad of a job. You do have to do a Z split like J suggested. A manual is helpful for the first time you do it. Its pretty clear once you get into it.
The hole in the bottom is for adjusting the clutch only. You can't get in there and get parts out through that little hole.
dc11
PostPosted: Wed Sep 22, 2010 1:34 pm    Post subject: Re: pto clutch repair on 550 oliver tractor Reply to specific post Reply with quote
thanks for your info
