8n hydraulic lift not working
ww123
PostPosted: Sun Oct 03, 2010 8:03 pm    Post subject: 8n hydraulic lift not working Reply to specific post Reply with quote
need some help. 8n 3pt will not lift, removed inspection plate pto in gear no spray evident, pump is turning, lift control arm up, plenty fluid, removed the small plugs on top of pump fluid discharged out but not much pressure. help dw
ZANE
PostPosted: Mon Oct 04, 2010 4:04 am    Post subject: Re: 8n hydraulic lift not working Reply to specific post Reply with quote
Take hold of the control rod down close to the bottom and with the PTO turning see if it will go forward???? If not then the control valve is stuck. It can usually be un stuck by moving the control rod back and forth till it comes loose.
Be sure that the little lever under the seat is in the up position for position mode. If it has been accidentally moved down in Draft mode it's a pretty good chance the draft mode does not come up. Draft mode is the first to stop working because of the beating it gets.
Zane
JMOR
PostPosted: Mon Oct 04, 2010 4:21 am    Post subject: Re: 8n hydraulic lift not working Reply to specific post Reply with quote
ww123 wrote:
(quoted from post at 00:03:51 10/04/10) need some help. 8n 3pt will not lift, removed inspection plate pto in gear no spray evident, pump is turning, lift control arm up, plenty fluid, removed the small plugs on top of pump fluid discharged out but not much pressure. help dw
Pressure builds as a result of a restriction. With the plug out, open flow, no restriction, no pressure.
ww123
PostPosted: Sun Oct 10, 2010 10:46 am    Post subject: Re: 8n hydraulic lift not working Reply to specific post Reply with quote
quote="ZANE"](reply to post at 13:04:57 10/04/10) [/quote]
okay, I checked the control rod and it does move forward and back, the draft control lever is in the up position still no response. What next?
As I mentioned in my original post when I removed the two small plugs at the top of the pump[with the pump running] I expected some high pressure to escape but just low pressure. Any ideas? Idea Confused ww123
JMOR
PostPosted: Sun Oct 10, 2010 12:46 pm    Post subject: Re: 8n hydraulic lift not working Reply to specific post Reply with quote
As I mentioned in my original post when I removed the two small plugs at the top of the pump[with the pump running] I expected some high pressure to escape but just low pressure. Any ideas? Idea Confused ww123[/quote]
I ain't Zane, but when he asks if control rod is moving, he most likely wants you to see that it moves forward enough to make the pivoting arm touch the pump casing as in picture.
ww123
PostPosted: Tue Oct 12, 2010 8:50 pm    Post subject: Re: 8n hydraulic lift not working Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 21:46:51 10/10/10) okay, I checked the control rod and it does move forward and back, the draft control lever is in the up position still no response. What next?
[/quote]
Yes the control rod does move the pivot arm to the case as in the photo. It moves it back and forth freely. ww123 Confused
