| Author |
Message |
buddy04 New User
Posted: Mon Jan 31, 2011 11:36 am Post subject: Serial number location on Super Major |
I have a Fordson Super Major/5000 that I am restoring. I believe it is a 1963. Where should the serial number be located. I have looked everywhere with no luck. Thanks for the help |
| Back to top |
wolfman Tractor Expert
Posted: Mon Jan 31, 2011 5:21 pm Post subject: Re: Serial number location on Super Major |
Raise the hood, look up around the battery box. |
| Back to top |
KFD68 Regular
Posted: Tue Feb 01, 2011 3:00 pm Post subject: Re: Serial number location on Super Major |
Lift up righthand side hood. Look at the front side of the block where it joins the cylinder head.
Flat area about 2 inch long x 1/2 inch deep
Serial number stamped into the face
you may have to clean the dirt to read it
post the number on here and I will date your tractor for you.
If you want the date of build, post the casting numbers off the block; gearbox & rear axle. |
| Back to top |
Chris Don Guest
Posted: Tue Feb 01, 2011 5:55 pm Post subject: Re: Serial number location on Super Major |
I beleve it is located on the right hand side of battery box when you are sitting in the seat.The panel that is between battery and fuel tank. |
| Back to top |
SuperMajor61 New User
Posted: Tue Feb 01, 2011 8:43 pm Post subject: Re: Serial number location on Super Major |
KDF68 is spot on ! On a Super the serial number will be found at the right front side of the block where it joins the cylinder head, this will be a raised flat surface. This is not the case with the regular Major nor the Power. |
| Back to top |
buddy04 New User
Posted: Thu Feb 03, 2011 10:33 am Post subject: Re: Serial number location on Super Major |
Thanks for the help. I was unsure if the serial number located on the motor was just the number for the motor or for the entire tractor. Thanks for clarifying. |
| Back to top |
Bendee Tractor Guru
Posted: Thu Feb 03, 2011 9:02 pm Post subject: Re: Serial number location on Super Major |
Not the case with my Super Major,I have the flat area without numbers, I suspect it is down near the starter motor somewhere,something to do. |
| Back to top |
KFD68 Regular
Posted: Sat Feb 05, 2011 10:19 am Post subject: Re: Serial number location on Super Major |
| KFD68 wrote: | (quoted from post at 00:00:35 02/02/11) Lift up righthand side hood. Look at the front side of the block where it joins the cylinder head.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
