| Author |
Message |
danny in draketown Regular
Posted: Wed Feb 23, 2011 1:20 pm Post subject: oil pick up tube |
1951 8n 12 volt side mount. when i pulled the oil pan off i noticed that the oil pick up tube had just a fuzz of play in it. where the tube mounts to the bracket on the block there is a hair line crack allowing it to move is this a big problem ? |
| Back to top |
Brian Bell Long Time User
Posted: Wed Feb 23, 2011 1:23 pm Post subject: Re: oil pick up tube |
I would think so. The tube mount is part of the front main bearing cap. I would tend to think a new cap and line bore is in order. Now, if the problem is in the pickup tube itself, I'd say get another one and get a machine shop to rebuild your pump and replace the pickup. If theres a crack, especially if it runs in or near the tube, how long before it breaks in half or starts leaking profusely? |
| Back to top |
Posted: Wed Feb 23, 2011 1:42 pm Post subject: Re: oil pick up tube |
its where the tube goes into the oil pump body.it looks like its it just has a little play in it. what holds those two together? |
| Back to top |
R Geiger Tractor Expert
Joined: 19 Apr 2009 Posts: 1772 Location: Banks, Oregon
Posted: Wed Feb 23, 2011 2:09 pm Post subject: Re: oil pick up tube |
i do believe they are silver soldered together. |
| Back to top |
DollarBill Long Time User
Joined: 28 Jul 2008 Posts: 1201 Location: Keystone Heights, Florida
Posted: Wed Feb 23, 2011 4:39 pm Post subject: Re: oil pick up tube |
| danny in draketown wrote: | | the oil pick up tube had just a fuzz of play in it. where the tube mounts to the bracket on the block there is a hair line crack allowing it to move is this a big problem ? |
Danny, that is the OIL PICK UP - If it has a crack, it could be sucking air. Air isn't a good lubricant.
If you don't repair or replace the tube, it will eventually break.
Fix it right while you have it apart. |
| Back to top |
Hobo,NC Tractor Guru
Joined: 14 Jun 2007 Posts: 10611 Location: Sanford, NC
Posted: Wed Feb 23, 2011 5:41 pm Post subject: Re: oil pick up tube |
| danny in draketown wrote: | | (quoted from post at 22:20:53 02/23/11) 1951 8n 12 volt side mount. when i pulled the oil pan off i noticed that the oil pick up tube had just a fuzz of play in it. where the tube mounts to the bracket on the block there is a hair line crack allowing it to move is this a big problem ? |
Originally they used lead solider,,, tip take yer pocket knife and see if you can dig into the solider,,, if so mark the tube in relationship to the end plate, heat it and pull the tube out... It must be free of all lead,,, re-solider with silver solider (even the crack) are pay someone who knows how to do it.. are buy a good used one...
All you need is the tube and end plate,,, the tube and end plate have nuttin to do with the line-bore...
| Back to top |
JEK1 Regular
Here is what that part looks like. You can buy this one very reasonable if you want. The tube look to be just lead soldered.
| Back to top |
JerryS Long Time User
Posted: Wed Feb 23, 2011 8:21 pm Post subject: Re: oil pick up tube |
By all means, fix it. If you don't, one day you will make a sudden stop (bang into a tree, e.g.) and your tractor will start making loud clattering noises. Expensive noises. |
| Back to top |
GAJIM Regular
Posted: Wed Feb 23, 2011 8:32 pm Post subject: Re: oil pick up tube |
I had a similar problem about 4 years ago and replaced the pick up tube. I did not realize it was sucking so much air. My hot idle oil pressure went from 20 to 40 psi. Do not take a chance - either fix it or replace it. GA Jim |
| Back to top |
Dunk Tractor Guru
Posted: Wed Feb 23, 2011 8:50 pm Post subject: Re: oil pick up tube |
I took mine out, cleaned it all good, then took about an hour, making sure that I had it EXACTLY right, and brazed it. |
| Back to top |
Posted: Thu Feb 24, 2011 12:11 pm Post subject: Re: oil pick up tube |
would that be like sweating copper tubing? |
| Back to top |
BillM (OH) Tractor Expert
Posted: Thu Feb 24, 2011 1:36 pm Post subject: Re: oil pick up tube |
Yes and no - silver solder has a higher melting point than lead solder and makes a much better fix on the tube. |
| Back to top |
Dunk Tractor Guru
Posted: Thu Feb 24, 2011 2:05 pm Post subject: Re: oil pick up tube |
| danny in draketown wrote: | | (quoted from post at 16:11:52 02/24/11) would that be like sweating copper tubing? |
If you are asking that about brazing, like BillM said, yes, but a lot hotter.
Even hotter for brazing, than silver soilder.
If you have no experience with brazing, DO NOT learn on this part.
Silver solder, maybe..... If you have experience with sweating copper. |
| Back to top |
Posted: Thu Feb 24, 2011 2:09 pm Post subject: Re: oil pick up tube |
where would i get silver solder and could i get it hot enough with my little propane torch or would i need a set of tanks ? |
| Back to top |
G6 at Snook, TX Tractor Expert
Posted: Thu Feb 24, 2011 2:32 pm Post subject: Re: oil pick up tube |
I would think that a machine shop could do this small job for you if you take them part. It would seem something they deal with occasionally. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
