| Author |
Message |
Bendee Tractor Guru
Posted: Fri Mar 04, 2011 5:21 am Post subject: Removal of grease nipple. |
One of the grease nipples [zerks to some] on the rear axle housing has blocked, it is a press in type,, is there a particular way to remove it or is it just a matter of drilling. any views would be appreciated. |
| Back to top |
d beatty Guest
Posted: Fri Mar 04, 2011 7:18 am Post subject: Re: Removal of grease nipple. |
Have you tried to put some heat on it and put grease gun to it and punp. This will some times open the pluged fitting. |
| Back to top |
CJ3b_jeep Long Time User
Posted: Fri Mar 04, 2011 11:01 am Post subject: Re: Removal of grease nipple. |
I saw a tool at one of the farm shows that you filled with grease and smacked with a hammer and it would clean them out. Heat usually works though. |
| Back to top |
Mike Farmer Long Time User
Posted: Fri Mar 04, 2011 11:29 am Post subject: Re: Removal of grease nipple. |
Hi. Is the little internal ball stuck upp or down. If its tight up I have used a very hin nail and a hammer and tapped it free. Then spray some WD40 or the like into the top of the nipple. Most times it will free itself. if its stuck down use a gently heat if that fails the only way I,ve found is to twist it with a pair of grips and replace it. Because if it is down you cant get grease past it.
Incidently where possible I tap the holes a fit screw in type, but thats rare. Luck.
MTF |
| Back to top |
Posted: Fri Mar 04, 2011 11:30 am Post subject: Re: Removal of grease nipple. |
It should say a very THIN nail |
| Back to top |
Bendee Tractor Guru
Posted: Fri Mar 04, 2011 11:00 pm Post subject: Re: Removal of grease nipple. |
Thanks people, I'll try those before the 3rd option. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
