Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Major engine hunts when cold
Post new topic    Yesterday's Tractors Forum Index -> Fordson
David Lewis
PostPosted: Sat Apr 02, 2011 5:47 pm    Post subject: Major engine hunts when cold Reply to specific post Reply with quote
1954 Major runs well, but the engine revs up and down when it is cold, and then evens out when warmed up. Feels like air is getting in somewhere, so went through the system last year and found no leaks. Did the diaphragm test and it seems OK. So what can I try now?
tiresntracks
PostPosted: Sat Apr 02, 2011 9:32 pm    Post subject: Re: Major engine hunts when cold Reply to specific post Reply with quote
It sounds like the damping valve in the vacuum governor may be broken.
David Lewis
PostPosted: Sun Apr 03, 2011 2:22 am    Post subject: Re: Major engine hunts when cold Reply to specific post Reply with quote
Interesting. Guess I can look that up in my parts book and then go take a look and see. Thanks for your help.
mick richman
PostPosted: Sun Apr 03, 2011 3:42 am    Post subject: Re: Major engine hunts when cold Reply to specific post Reply with quote
Had the same problem. Ended up partly dismantling the fuel pump and found the diaphragm was split. Not too hard to get out except for the fourth bolt.
David Lewis
PostPosted: Sun Apr 03, 2011 4:17 am    Post subject: Re: Major engine hunts when cold Reply to specific post Reply with quote
That makes sense, because it stops hunting at very low idle, i.e. is getting enough diesel when it only needs a little. Will check it out. Thanks.
richard bartlett
PostPosted: Mon Apr 04, 2011 9:34 am    Post subject: Re: Major engine hunts when cold Reply to specific post Reply with quote
just another thought, mine's a 1955 FMD and had similar problem, the diaphram was split so replaced it but I also discovered one of the two pipes that run from the top of the diaphram housing to the manifold had been rubbing on the engine block and had a hole worn in it.
David Lewis
PostPosted: Mon Apr 04, 2011 12:46 pm    Post subject: Re: Major engine hunts when cold Reply to specific post Reply with quote
Thanks for the idea. I thought cracked pipes might be the prolem last year, so I tested them and they are OK. So I suspect it's vacuum pump diaphragm or fuel pump diaphragm - both easy fixes (if I get lucky).
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
