Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Naw, it wont blow up!
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford
Ultradog MN
PostPosted: Fri Apr 08, 2011 10:04 am    Post subject: Naw, it wont blow up! Reply to specific post Reply with quote
Jerry "You sure it wont blow up?"
Kenny, "Naw. I soldered up a lot of diesel tanks in my day and never had a problem."
Jerry " Well I'm a little skeert"
Kenny " "Naw, it's ok"
Jerry " How come you're standing so far away?"
Kenny "Well, I didn't want to be in your way. Wink, wink."
Jerry "I could fill the tank almost full of water and solder it that way"
Kenny "Naw it wont blow up."
Jerry "Well ok, here goes."
So I had the oxy/acetylene squeezed down real low so I wouldn't have too hot of a flame. Had to melt the old solder off so we could clean it up and resolder the brass bung to the tank. Old solder had cracked and was leaking.
I got the area hot and just had the solder to melt and was sliding the bung off the tank when KaWhooosh!!
Blue smoke blew out of the fill neck and the hole for the fuel guage and left a big plume in the shop.
Ken's wife Carol (who was down at the shop painting some picture frames) "AAAUUUUGGGHH"
Kenny "Chuckle, chuckle, snicker, snicker."
Jerry " What the...! I thought you said it wouldn't blow up!"
Kenny "Chuckle chuckle snicker, snicker"
Carol "Aaaauuuggghh!"
Jerry "You said it wouldn't blow up."
Kenny "It didn't blow up. snicker, snicker. Sometimes they will go wooof a little but that doesn't hurt anything. chuckle chuckle"
So I cleaned up the old solder area and put some flux on it and was going to solder the bung back on.
Kenny "Naw. They never blow up. Sometimes they'll whooof a little but they never blow up. Gas tank will blow up but not a diesel."
Jerry "Well ok. Here goes."
Carol "AAuuughh."
Kenny "Chuckle, chuckle, snicker, snicker..."
So I soldered it back on and pressure tested it and no leaks.
I guess Kenny is right.
Sometimes they woof a little but they never blow up.
"Aaauuuggghh"
Fordfarmer
PostPosted: Fri Apr 08, 2011 10:11 am    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
Kenny "It didn't blow up. snicker, snicker. Sometimes they will go wooof a little but that doesn't hurt anything. chuckle chuckle.
I can just about hear Kenny. Smile
Glad it was you soldering it, not me.
RodinNS
PostPosted: Fri Apr 08, 2011 11:44 am    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
If I've said this once.... I've said it a hundred times... the LEL (Lower Explosive Limit) of diesel fumes and gasoline fumes are nearly identical. Gasoline has a wider explosive range IIRC... but both are dangerous.
You will not ever catch me welding on a diesel tank or gas tank without full flow air ventilation or a good filling of CO2.
Rod
Jim in Ma.
PostPosted: Fri Apr 08, 2011 11:50 am    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
Ya I have seen that and it does get your attention.
I have soldered many tanks - gas and diesel.
I never put a flame to the tank. I use an old prybar as a soldering iron. Works for me.
View user's profile MSN Messenger
showcrop
PostPosted: Fri Apr 08, 2011 3:24 pm    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
I had to make the same repair on a blue tank last spring. Along with a few ounces of residual fuel in the tank there was some organic crap that caught fire while I was soldering. It went out after awhile. Didn't hear any wooof though.
TMo
PostPosted: Fri Apr 08, 2011 5:01 pm    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
I second your post. Just because you have done something a hundred times with flammable substances doesn't mean an accident ain't waiting to bite your arss. I lit a fire to a burn pit full of debris, done it a hundred times, before I knew it....BOOM! SOB flared up and before I knew it I was back first in it. Luckily, only 2nd and 3rd degree burns on my right arm from the fingers to the arm pit. Hurts like nothing you have ever experienced!!
Hobo,NC
PostPosted: Fri Apr 08, 2011 5:31 pm    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
About this time last year I had to relocated the pick up tube and relocate a new fuel sender on a tank out of a 39 chevy street rod,,, best I could figger out was the tank came out of a AMC javelin,,, it did fit up nice but a hack job was done connecting the fuel line to it and the sender did not match the gauge...
I washed it out a few times,,, then stood it up around the corner of the building and while around the other corner stuck a torch in the fuel sender hole... "AAAUUUUGGGHH" big time,,, I repeated till no "AAAUUUUGGGHH",,, then solider in all the new parts no problem... I stood it up on end to get all the water to run to one corner,,, next day go to suck it out,,, I get almost a qt of raw fuel out of it :shock",,, it had a plastic tank inside the tank that has something to do with the vent and I did not see it...
Paul in MN
PostPosted: Fri Apr 08, 2011 6:59 pm    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
Jerry,
I'll bring you the tank from my 8000 when we get to fixing it. I'm not putting a torch on the darn thing. I got 8 grandkids, and that means about 10 years of tractor building, so I don't want any missing body parts from some big WOOOOSHHHH! I'll even buy both you and Kenny a few beers to celebrate another successful tank soldering job.
Just Kidding, but maybe not?
Paul in MN
Ultradog MN
PostPosted: Sat Apr 09, 2011 3:52 am    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
Hi Paul.
Ken has been around and repaired more big equipment in his life than I will ever see.
I trust him implicitly.
Six years ago I soldered the gas tank on my 3000 but only after washing it out with lacquer thinner, then soap and water and then letting it air out for a few days.
Sure I could solder your tank. Sometimes the bottoms are like swiss cheese from rust and then not worth it. But a pinhole or two or a crack or a leaking bung is not difficult or particularly dangerous.
Let me know.
Ultradog MN
PostPosted: Sat Apr 09, 2011 3:56 am    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
It's that first wave of the torch over the hole that really makes the ol sphincter tighten. Once you get past that you're ok. Your job would have given me nightmares afterwards.
JMOR
PostPosted: Sat Apr 09, 2011 7:28 am    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
To each his own, but I personally won't apply flame to a fuel or oil tank unless I'm purging it with a flow of CO2 at the time. I witnessed my dad being blown 10-15 feet across the yard with the round end of a tractor tank (MM I think) wrapped around his face. He previously rinsed with water, dumped & re-filled with water, being careful to not leave air space, and had already had flame applied for a minute or more when it blew up. He always surmised that there was fuel remaining in the seams that the heat liberated that resulted in the explosion. He didn't stop doing it, but he always ran purging gas during welds after that & never had another blow.
fordtractor2000
PostPosted: Sat Apr 09, 2011 5:28 pm    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
LEL of gas is -45 deg. and diesel is 145 deg. so how are they close ??
JMOR
PostPosted: Sat Apr 09, 2011 6:13 pm    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
fordtractor2000 wrote:
(quoted from post at 21:28:04 04/09/11) LEL of gas is -45 deg. and diesel is 145 deg. so how are they close ??
Lower Explosive Limit is expressed as a %..........so what is your degrees?
OK, your degrees numbers are flash point, i.e., the temperature where an explosive vapor can form. Well, torch temperatures FAR exceed either one by one or two orders of magnitude, so your point is???
2fordsmike
PostPosted: Sat Apr 09, 2011 6:21 pm    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
I have two stories: Wife's uncle's friend welding hotrod gas tank. Dead! Local kid welding muscle car gas tank. Little bitty ears, nose, lips, eyelids, eyebrows; stubby fingers, all visible skin appears melted. Very lucky to be running repair shop 10 years later. Wonderful attitude.
36 Coupe
PostPosted: Sun Apr 10, 2011 12:39 am    Post subject: Re: Naw, it wont blow up! Reply to specific post Reply with quote
You never heard of an electric soldering iron or and old soldering copper you can heat with a torch I guess.
Goto page 1, 2  Next
Page 1 of 2
