TO35 input shaft seal
Goto page 1, 2  Next
Bill in CA
PostPosted: Sun May 15, 2011 9:14 am    Post subject: TO35 input shaft seal Reply to specific post Reply with quote
I'm trying to replace trans input shaft seal in 1955 TO35 dual clutch - I've got the housing loose - removed the cover for the counter shaft and removed the circlips/snap rings and installed bolt in counter shaft but shaft will not move forward - is there something I'm missing or do I need to do more dis-assembly. I need help/advice so I can replace clutch and get back using tractor. Thanks
Tony in Mass.
PostPosted: Sun May 15, 2011 9:59 am    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
I am in the same boat. April 20th 18;35 or so you will find my post with pics of the same deal. Steve L. got into this with a single stage clutch, but I rckon we got another ring or something hanging up the job. I will try to repost the pics now it I can find them-
Bill in CA
PostPosted: Sun May 15, 2011 1:55 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
Thanks for the reply Tony, I missed your previous post, but I did find an earlier post (see link below) if I read it right - all you need to do is remove that round cover below the input shaft and pull the counter shaft out and down and the input shaft should come right out - I even talked to a tech at the local tractor shop and he said basically the same thing - although he was hesitant to give more info (would rather me take it to his shop) my counter shaft only moves out about half an inch then stops - I know my shaft seal leaks because I have to keep adding gear oil and I'm replacing the clutch (was oil soaked). I haven't taken off the top cover as yet - did you find anything in there that would release the input shaft?
Untitled URL Link
samn40
PostPosted: Sun May 15, 2011 3:16 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
The shaft needs to go back into the 'box to let the gear drop down slightly on the dual clutch model. The threaded hole in the shaft is for pulling it back out into the gear and bearing. On a 135 you actually have to split the gearbox off the tranny housing to let the shaft back but not on your 35 model.
Hope this helps ....Sam
Bill in CA
PostPosted: Sun May 15, 2011 4:56 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
Thanks, I'll give that it a try - all this time I've been trying to pull it out and I should be pushing it in - now that makes more sense, I couldn't figure out why that cir-clip had to be removed if the shaft moved out. It keeps it from moving in.
Thanks again.
Tony in Mass.
PostPosted: Sun May 15, 2011 5:16 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
Uh huh. I got the drift of guys talking about the lower shaft, that I call the pto shaft, which if the front section of that came out, yeah, the teeth on the gear of the upper shaft wouldn't be meshed into anything, and the cone? with the square hole could/ may come forward.... I wasn't intending to field strip this thing to the swinging drawbar, but I am working my way in that direction.
Tony in Mass.
PostPosted: Sun May 15, 2011 5:43 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
You found that from 2002? I didn't think Al Gore invented the internet till 04... yep, the names are changed, but the idea is the round plate on the bottom has to come off, the end of the shaft in there has to come out- however, and THEN the main shaft cone housing will come forward and the world will be a happier place for it. Trouble is, I don't know if the seal was even leaking, but now that I am this far, and have a new seal here already.... got to jump in with both feet huh?
Steve Lundborg
PostPosted: Mon May 16, 2011 11:56 am    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
Tony, I've been pouring over my manual for you to figure out what you need to do. The reason you can't pull out your input shaft housing is that you need to pull out the live pto shaft, which is behind the plate below the input shaft housing.Nice picts btw,then using internal snap ring pliers remove the snap ring, then you can remove the shaft. There are internal threads on the end of the shaft to aid in pulling it out. (The manual shows a somewhat complicated procedure for reinstalling it.)With the live pto shaft removed the mainshaft carrier should just pull out.
Now if anyone can instruct me on the proper procedure for removing the main drive shaft seal without damaging the main drive shaft retainer assembly on a single shaft drive I will be forever grateful.The manual stops short here in explaining this. The seal sits halfway in the housing behind a washer like part at the end of the shaft where it meets the larger part of the housing. I started to drive the washer out thinking is was the seal with a pipe before realizing that something was wrong. I've never removed a seal from a rabbit hole before.
Bill in CA
PostPosted: Mon May 16, 2011 12:42 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
Hey Steve,
Does your manual say whether or not the trans/pto have to be in any particular gear/position - I removed the snap ring and the pressed off the bearing - and the shaft itself will not move out what I believe is the carrier inside the gearbox - when you say out, you do mean toward engine - samn40 stated into gearbox -I can't get mine to move either way - it only moves the whole thing not just the shaft - pretty frustrated at this point.
Steve Lundborg
PostPosted: Mon May 16, 2011 3:47 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
Bill,
The manual says:Remove the live PTO shaft by sliding it out of the front of the transmission. This allows the PTO drive gear to drop down so the main drive shaft retainer can be removed. That's what your picture shows, in the manual diagram this shaft is coming straight out. The end of the shaft is threaded, a bolt might give you some purchase,as this needs to slide through the PTO drive gear, there also appears to be another snap ring before the drive gear in the diagram.I also live in California.
samn40
PostPosted: Thu May 19, 2011 2:19 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
I just done the seals in a 65 today and the shaft had to go back like a 135.Instead of splitting the gearbox off the trans housing ,I removed the hydraulic pump.
As I said before on early tractors you don't have to do this but I think from your pics that your gearbox is like the 135....so the shaft needs to go back.
Sam
Bill in CA
PostPosted: Thu May 19, 2011 5:32 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
Thanks for the input - but thanks to Steve L who sent me info on my dual clutch set up the shaft does indeed pull forward towards the engine - once you remove the bearing assembly on shaft - there is a thrust washer on the shaft that comes off to reveal as snap ring that holds the counter shaft in - remove the snap ring and the shaft pulls forward - I will post pictures of the process when I re-assemble (I couldn't on dis-assembly because it was raining)
sperkes
PostPosted: Wed Feb 22, 2017 5:19 pm    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
Bill in CA wrote:
(quoted from post at 18:32:20 05/19/11) Thanks for the input - but thanks to Steve L who sent me info on my dual clutch set up the shaft does indeed pull forward towards the engine - once you remove the bearing assembly on shaft - there is a thrust washer on the shaft that comes off to reveal as snap ring that holds the counter shaft in - remove the snap ring and the shaft pulls forward - I will post pictures of the process when I re-assemble (I couldn't on dis-assembly because it was raining)
Hoping to get some feed back from this post. I have a to35 that I am having issues getting the input shaft out.
Hirschi
PostPosted: Tue Mar 07, 2017 5:31 am    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
did you ever post the pictures? I am also in the same boat, tractor currently split and trying to change oil seals on the pto input shaft.
I started this journey by needing to change the PTO clutch plate that a previous owner bent on installation and it finally shed all of its linings...
Thanks!!
Hirschi
PostPosted: Tue Mar 07, 2017 5:34 am    Post subject: Re: TO35 input shaft seal Reply to specific post Reply with quote
sperkes, did you get it figured out? The previous posts give a lot of great info, but I also would like to see pictures just before I start into it so I don't miss something.
Goto page 1, 2  Next
Page 1 of 2
