| Author |
Message |
Brian Dan Regular
Posted: Thu Jul 21, 2011 4:19 pm Post subject: Wisconsin VF4D timming |
I have a Wisconsin VF4D engine. It had no spark. I removed the magneto so I could work on it.
Are there timming marks on the gears that mate with the magneto? I see the x mark on the magneto but can't locate the other x mark.
What am I missing? |
| Back to top |
JOB Long Time User
Posted: Thu Jul 21, 2011 5:51 pm Post subject: Re: Wisconsin VF4D timming |
Remove the screen that covers the flywheel.That will expose the timing marks that are on the flywheel shroud. The flywheel is marked with the letters DC near one of the flywheel fins. the fin is further identified by an X mark cast on the end of the fin. Turn the engine over until edge of the marked fin on the flywheel is on line with the mark on the vertical line of the shroud. At this point the key way for mounting the flywheel is also on top. The magneto should now be fitted to the engine so the X marked tooth of the magneto gear is visible through the lower half of the inspection hole.
If the magneto is properly timed the impulse coupling will snap when the DC X marked fin lines up with the center line of the number 1 and 3 cylinder as marked on the flywheel shroud. |
| Back to top |
Brian Dan Regular
Posted: Fri Jul 22, 2011 10:52 am Post subject: Re: Wisconsin VF4D timming |
Thank You! It took me a couple of tries but I did get the magneto back in and the engine now runs great. |
| Back to top |
greygoat Tractor Expert
Posted: Sat Jul 23, 2011 4:37 am Post subject: Re: Wisconsin VF4D timming |
A Wisconsin owners manual has some very nice
pictures of how to do that, and a good explanation. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
