| Author |
Message |
BWOODS New User
Posted: Fri Sep 09, 2011 4:41 pm Post subject: blow-by on new rebuild (fordson dexta) |
I JUST REBUILT MY 1958 FORDSON DEXTA. I REDONE THE WHOLE ENGINE, EVERYTHING NEW EXCEPT THE CRANK WITCH CHECK OUT OK, HAD SLEEVES DONE AT MACHINE SHOP AND DONE THE HEAD ALL NEW PARTS. NOW FOR THE PROBLEM, WHEN I CRANKED IT THERE IS ALOT OF BLOW-BY COMEING OUT OF THE VALVE COVER THROUGH THE VENT PIPE WITH A LITTLE OIL TOO, AND ALSO IT IS PUSHING OIL OUT OF THE DIP STICK, A PRETTY GOOD DRIP. IT RUNS GOOD AND SOUNDS GOOD. WILL IT CLEAR UP WHEN EVERYTHING SEALS OR AM I GOING TO HAVE TO START OVER ??? |
| Back to top |
KSTractor Regular
Posted: Sun Sep 11, 2011 2:44 am Post subject: Re: blow-by on new rebuild (fordson dexta) |
Take it out and work it hard don't overload it but make it work. Work it for 20 minutes then idle for 5 then work a little harder for 30 then idle for 5 etc after a few hours the rings should be broke in. |
| Back to top |
retired farmer Long Time User
Posted: Sun Sep 11, 2011 6:30 pm Post subject: Re: blow-by on new rebuild (fordson dexta) |
Never worked on one before so I don't know what the rings look like, but all the rings I have installed on other engines have a mark on them, to show the top side of the ring. You did install the rings the right way? Don't know how much that would contribute to excessive blowby if they were installed upside down. |
| Back to top |
jd b puller Tractor Expert
Joined: 07 Jul 2001 Posts: 3165 Location: North Carolina
Posted: Mon Sep 12, 2011 8:22 pm Post subject: Re: blow-by on new rebuild (fordson dexta) |
If you put the rings in upside down, you will get blowby. There should be a bevel on the inside of the ring. This normally needs to go up so that the compression pushes the ring out and seals the cylinder better. |
| Back to top |
BWOODS New User
Posted: Tue Sep 13, 2011 2:15 pm Post subject: Re: blow-by on new rebuild (fordson dexta) |
thank you !! if they had a bevel side i missed it, and i was looking hard for one, i hope i don't have to pull that thing back apart ???? |
| Back to top |
Bendee Tractor Guru
Posted: Fri Sep 16, 2011 2:14 am Post subject: Re: blow-by on new rebuild (fordson dexta) |
Do you have the manual? one and two and one oil ring are conventional. Number 3 and one oil ring must be installed in a particular manner. |
| Back to top |
Tramway Guy Tractor Expert
Posted: Fri Sep 16, 2011 2:01 pm Post subject: Re: blow-by on new rebuild (fordson dexta) |
What do you mean " had sleeves done at machine shop"?? If they just 'cleaned them up' and you re-used the original pistons, that could be your problem.
Just wondering. |
| Back to top |
miner09 Long Time User
Posted: Fri Sep 16, 2011 5:47 pm Post subject: Re: blow-by on new rebuild (fordson dexta) |
You have ring's on wrong side up or the wrong size rings. |
| Back to top |
J.WJansen Regular
Joined: 09 Apr 2009 Posts: 72 Location: Netherlands (Holland)
Posted: Wed Sep 21, 2011 12:40 pm Post subject: Re: blow-by on new rebuild (fordson dexta) |
Check engine repair manual at:
http://www.fordson-dexta.de/downloads/section3.pdf
See Section 3 page 15 for pistons and rings.
Also you can try to ask on www.fordsontractorpages.nl
| Back to top |
BWOODS New User
Posted: Fri Sep 23, 2011 3:06 pm Post subject: Re: blow-by on new rebuild (fordson dexta) |
you hit the nail on the head !!!! i tore it back down and russell tractor sold me the wrong rings, i guess it's my fault for not checking the ring gap, that's what getting in a hurry will do for you. i had 3/8" ring gap. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
