Smokes and does not stop
salvador
PostPosted: Sun Sep 18, 2011 4:05 pm    Post subject: Smokes and does not stop Reply to specific post Reply with quote
I just got a Power Major. It starts right away but it smokes a lot and the pump lever does not move at all. I think there is excess fuel and the rack is stuck. What should I do first? Is it OK to take off the pump plate to try to liberate the rack?. Thank you.
Salvador
CaptainD51
PostPosted: Wed Oct 05, 2011 6:06 pm    Post subject: Re: Smokes and does not stop Reply to specific post Reply with quote
I recently had to work on my (new to me, Fordson major Diesel) because the rack was stuck.
No problem removing the "SIMMS" plate, just try to keep things clean and I did not loosen the metering levers, just cleaned the rack and made sure it slid back and forth. Lubricated it, cleaned out the fuel shut off and extra fuel "button".
I also took apart the governor and checked the below to make sure it did not have any tears. Be careful if you take that apart, there is a small spring and check ball that you do not want to lose.
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
