Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
kohler command 25 hp
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines
PAQ
PostPosted: Thu Sep 29, 2011 5:39 pm    Post subject: kohler command 25 hp Reply to specific post Reply with quote
I have an Allmand loader backhoe that is powered by a Kohler command 25 hp engine.
It starts well, seems to have good power and it saves my back on at least a daily bases. The problem is that when it is hot and you shut it off for a short time and restart it, it will run on one cylinder for a while. Sometimes it picks up the second cylinder suddenly and sometime gradually. The book doesn’t give me a clue as to the problem. Sometimes it pops on shutdown which makes me think exhaust valve but compression seems good. I replaced the plugs and air filter.
So any suggestions?
Thank you in advance
Kentb of SWMO
PostPosted: Fri Sep 30, 2011 6:11 am    Post subject: Re: kohler command 25 hp Reply to specific post Reply with quote
Try checking the fire on the cylinder that is missing with a inductive timing light. If you have intermittent fire, I would replace the coil for that cylinder as it may have developed a heat problem. You could also swap the coil to see if the miss moves. One of the coil could be failing because of heat.
I had this same thing happen on a 22 HP Command engine. I thought the engine was tried as it was on a zero turn mower the local school used that had POOR air filter maintenance. I install a new engine. Later after seeing the inside a a single cylinder command engine that had eaten WAY more dirt that the v-twin had I took the V-twin apart. I could find NOTHING wrong with it. Later because of some operator errors, this engine was put back on the mower it came from. It seems to be running well. I do not know WHAT made it run poorly in it's earlier life.
Kent
PAQ
PostPosted: Fri Sep 30, 2011 12:46 pm    Post subject: Re: kohler command 25 hp Reply to specific post Reply with quote
Thanks kent.
I will try that this weekend. It does seem like the kind of thing a weak electrical component would do.
PAQ
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines All times are GMT - 8 Hours
