Can't remove Rear Wheel Hub on my '48 8N?
8nModesto
PostPosted: Tue Oct 04, 2011 12:13 pm    Post subject: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
Can't remove the rear hub. Tried everything..including heat and tapping. See photo with large 3-point puller. Even the puller screw is bending with the pressure.
Followed Smith's instructions...FO-4 instructions...everything I could read so far. Won't budge. The nut is turned away so there is room for the hub to pop off. Need to replace the outer seal and gasket to stop grease leak. HELP!
Bob
PostPosted: Tue Oct 04, 2011 12:37 pm    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
You need a bigger/more HD puller.
The coarse thread on the force screw of the one you are using tells me it's not a real high-powered unit.
36 Coupe
PostPosted: Tue Oct 04, 2011 3:37 pm    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
The puller is too flimsy for the work.A wheel puller has a larger screw and has a wrench that can be struck with a hammer to tighten the screw.The end of the screw has to be hit with a hammer when the puller is tight.The puller you have is just too light,Time to rent a real one.Get some Kroil too.
Toolkat1
PostPosted: Tue Oct 04, 2011 5:50 pm    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
You will need a stout wheel hub puller made for the purpose. I know snap on sells one, was about $100 when I bought mine about 8 years ago.
Toolkat
JMOR
PostPosted: Wed Oct 05, 2011 2:06 am    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
8NModesto wrote:
(quoted from post at 16:13:12 10/04/11) Can't remove the rear hub. Tried everything..including heat and tapping. See photo with large 3-point puller. Even the puller screw is bending with the pressure.
Leave the nut loose as you have it & put wheel back on and plow the north 40 and see it work loose.
DollarBill
PostPosted: Wed Oct 05, 2011 2:46 am    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
As others have mentioned, you've sent a boy to do a mans job. Here's what you'll need to part the hub from the axle.
HUB PULLER
NOXJohn
PostPosted: Wed Oct 05, 2011 3:34 am    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
When I have a stuck hub I use a big wedge (old axe head) and a BFH. Put the wedge between the hub and the bearing cap. Make sure you line it up so the wedge is hitting one of the round headed bolts on the bearing cap and the back of one of the lugs on the hub. Hit the wedge with the BFH. Turn hub and line up with another lug bolt and hit again. After a couple of hits it will come off. Wear eye protection in case of flying broken off pieces of metal. Make sure to line up with round headed bolt on bearing cap. If you line up with one with a wrench headed bolts you may mess up the head to where a wrench will not fit. This has always worked for me.
oldtanker
PostPosted: Wed Oct 05, 2011 8:09 am    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
DollarBill wrote:
(quoted from post at 03:46:17 10/05/11)
HUB PULLER
I picked one of those up at an auction for 60 bucks last year....right before I had to replace the seals on my 8N Very Happy Very Happy Very Happy
Rick
View user's profile Yahoo Messenger
ZANE
PostPosted: Wed Oct 05, 2011 3:42 pm    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
Back when I worked for the Talladega County road department we had an older mechanic that had been at it for about 50 years. When he had to remove the big track sprocket from a dozier final drive all he did was take the nut off the shaft and with a 20 pound hammer he would whack the outer edge of the sprocket hard as he could swing that big hammer and after just a few well aimed licks that sprocket would fly off onto the floor like it was shot from a gun.
I've dont it with the 8N hub too. It's a two man job though and it has to be someone good with the hammer. Use a big drift that will just fit between the lugs on the hub and about a foot long and get the hammer man to strike it hard as he can. It helps if he can hit the drift every time and not your or the hub.
Knock it toward the axle.
Won't hurt to leave the puller on tight as you can get it too. The jarring will probably shake it off though after a few licks.
Zane
8nModesto
PostPosted: Wed Oct 05, 2011 5:58 pm    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
THANKS to all of you. Got the hub off today...used a bit of everyone's advice. borrowed a big Heavy Duty Hub Puller with an 1-1/8" screw from my welder friend. Cranked it tight and with one hard swing of a 4-lb hammer on the back of the hub it popped right off the taper. Just finished putting new seal and gaskets and put everything back together including new brake shoes. Put new screws in for the brake drum and re-installed tire and wheel after changing the dish-pan center to the inside of the rim.
Tomorrow I will now do the other side. Thanks again for all your help. The forum is just great.
Hobo,NC
PostPosted: Wed Oct 05, 2011 6:27 pm    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
For the record you can pull the hole deal out axle and all and put it in a press... I am tired of mess'n up good pullers on a N axle,,, press and heat if needed.... A stuck hub is good believe it are not.... Your pocket book will know the feeling of a loose one...
[url][/url]
JMOR
PostPosted: Wed Oct 05, 2011 6:49 pm    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
Hobo,NC wrote:
(quoted from post at 22:27:54 10/05/11) For the record you can pull the hole deal out axle and all and put it in a press... I am tired of mess'n up good pullers on a N axle,,, press and heat if needed.... A stuck hub is good believe it are not.... Your pocket book will know the feeling of a loose one...
[url][/url]
Now that will "get 'er dun!".
Harry Wilken
PostPosted: Mon Oct 10, 2011 7:47 pm    Post subject: Re: Can't remove Rear Wheel Hub on my '48 8N? Reply to specific post Reply with quote
WOW. that is one nice way to do it. Both my hubs were badly worn. I bought a large hydrulic three claw puller for the job. Went to pull them and hubs fell off. Really worn.
