New winch
Goto page 1, 2  Next
Heavyduty1
PostPosted: Mon Oct 31, 2011 11:30 am    Post subject: New winch Reply to specific post Reply with quote
Got my new NT winch installed. It's rated for 12,000lbs and it pulled my 4020 with loader onto the trailer with no problems. It has also has the wireless remote so I can stay outa the way. Laughing
Jim in Ma.
PostPosted: Mon Oct 31, 2011 1:20 pm    Post subject: Re: New winch Reply to specific post Reply with quote
Now - That is the way to mount it.
It makes the winch a lot more versital.
View user's profile MSN Messenger
Heavyduty1
PostPosted: Mon Oct 31, 2011 2:50 pm    Post subject: Re: New winch Reply to specific post Reply with quote
Yep, I can take it off the trailer in seconds to keep out of the rain and sticky fingers is another reason we installed it that way. I also installed the 175 amp quick connects for electric.
I had a breakdown this summer on the 4020 in the middle of knowwhere and it sure would have been nice to load it up to work in the shop.
ScottyHOMeY
PostPosted: Mon Oct 31, 2011 4:26 pm    Post subject: Re: New winch Reply to specific post Reply with quote
Nice setup!
Heavyduty1
PostPosted: Mon Oct 31, 2011 4:33 pm    Post subject: Re: New winch Reply to specific post Reply with quote
Thanks. Going to paint it all black soon, to match the rest of the trailer.
mkirsch
PostPosted: Tue Nov 01, 2011 4:43 am    Post subject: Re: New winch Reply to specific post Reply with quote
Do you happen to have a picture further out that shows where exactly you mounted it on the trailer?
Yours looks like it's mounted on the tongue, offset to the right.
I'm looking for ideas how to mount a winch on my trailer. Right smack in the middle would be great if not for the 12,000lb jack welded to the front of the trailer deck in the way.
bjb in TX from Ne
PostPosted: Tue Nov 01, 2011 7:20 am    Post subject: Re: New winch Reply to specific post Reply with quote
That pin holding it looks a bit small...
luv2wrench
PostPosted: Tue Nov 01, 2011 9:45 am    Post subject: Re: New winch Reply to specific post Reply with quote
does the truck supply the battery power or does a battery?? looking to see if i should make cables to my truck or not and what type of connections. picts would be nice.
mkirsch
PostPosted: Tue Nov 01, 2011 10:35 am    Post subject: Re: New winch Reply to specific post Reply with quote
bjb in Tx from Ne wrote:
(quoted from post at 08:20:29 11/01/11) That pin holding it looks a bit small...
That is a standard 2" receiver with a 5/8" cross pin, same as any trailer hitch on any truck.
That 5/8" pin is good for towing an 18,000lb trailer. If it can't hold up to the force from a 12,000lb winch, we should all just run and hide.
Heavyduty1
PostPosted: Tue Nov 01, 2011 11:54 am    Post subject: Re: New winch Reply to specific post Reply with quote
mkirsch wrote:
(quoted from post at 13:43:18 11/01/11) Do you happen to have a picture further out that shows where exactly you mounted it on the trailer?
Sure do. It's not real clear but this is what I have.
Heavyduty1
PostPosted: Tue Nov 01, 2011 11:59 am    Post subject: Re: New winch Reply to specific post Reply with quote
(quoted from post at 16:20:29 11/01/11) That pin holding it looks a bit small...
Yeap, the welder said if I put a snatch block rated for 20k, I would need to drill holes for a extra pin about a foot back from the one that's in now..
Heavyduty1
PostPosted: Tue Nov 01, 2011 12:07 pm    Post subject: Re: New winch Reply to specific post Reply with quote
luv2wrench wrote:
(quoted from post at 18:45:51 11/01/11) does the truck supply the battery power or does a battery?? looking to see if i should make cables to my truck or not and what type of connections. picts would be nice.
The truck (Ford F-800) twin batterys already have a quick connect for the elec motor for the trailer ramps. I just unplug the trailer and plug in the winch. I leave the truck running when winching anything. I might try and get a better pic in a few days of the quick connects and the elec motor setup for the ramps.
Heavyduty1
PostPosted: Tue Nov 01, 2011 12:17 pm    Post subject: Re: New winch Reply to specific post Reply with quote
mkirsch wrote:
(quoted from post at 19:35:34 11/01/11)
That's why I got the wireless option for this winch, I can hide about 80+ft from the winch, like I did on this test run with the 4020/loader (roughly 12,000 lbs). Smile
Jahaze
PostPosted: Tue Nov 01, 2011 4:08 pm    Post subject: Re: New winch Reply to specific post Reply with quote
What gauge are your quick disconnect cables?
Heavyduty1
PostPosted: Tue Nov 01, 2011 5:02 pm    Post subject: Re: New winch Reply to specific post Reply with quote
Jahaze wrote:
(quoted from post at 01:08:37 11/02/11) What gauge are your quick disconnect cables?
2 gauge. I ran the winch a couple times and the cables stayed cool.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
