CA PTO clicking
TFLundyB275
PostPosted: Sun Nov 06, 2011 5:19 pm    Post subject: CA PTO clicking Reply to specific post Reply with quote
Hi, I have seen other posts concerning this problem, but with no answer. I thought I'd try and add some more info.
I was using my Allis CA to power my cordwood saw for this seasons firewood. First time using the belt since Ive gotten the tractor three years ago. On the first day of sawing, after about 3 hours, it happened out of the blue, on at idle.
Its a click-click-click from the pto area. Now this seems to be from the pto, and not the hydraulics. With no load, the clicking will start after a certain RPM is reached from releasing the clutch. Using the hydraulics does not have any affect on the sound. Tractor has no other problems since.
When I first got her I did a do over and put in a new pto bearing, also making sure the the four hydraulic values were free. Everything inside looked solid and clean. Using fresh hydratrans in it now. Cant remember if I did a new belt pullet bearing, but I imagine I did.
So, whats causing the noise? Safe to use or no?
Dick L
PostPosted: Sun Nov 06, 2011 6:52 pm    Post subject: Re: CA PTO clicking Reply to specific post Reply with quote
Have you checked the pully to make sure the nut is tight? My guess would be a loose pulley or the belt lacing is starting to come apart. I can not hear it but shouldn't be any thing inside that would just click unless the pulley shaft nut didn't get staked and came loose some.
TFLundyB275
PostPosted: Sun Nov 06, 2011 7:44 pm    Post subject: Re: CA PTO clicking Reply to specific post Reply with quote
Thanks for responding. The pulley is tight. And the clicking occurs with the belt on or off.
I did forget in my original post this bit of information. With the tractor off, I can turn the pto by hand. It is smooth turning, except this one spot is noticeably different. I imagine that spot is what is making the click, but what "that" is I dont know?
Aaron SEIA
PostPosted: Mon Nov 07, 2011 5:31 am    Post subject: Re: CA PTO clicking Reply to specific post Reply with quote
Is the click at the same point in every rotation? You might have a bent or missing tooth on a gear.
AaronSEIA
Brian Jasper co. Ia
PostPosted: Tue Nov 08, 2011 8:40 pm    Post subject: Re: CA PTO clicking Reply to specific post Reply with quote
Most likely it is the hydraulic pump. There are 4 plungers that are spring loaded with roller followers on cams on the pto shaft. I found on my CA that it had a plunger spring broken. The plunger was stuck in all the way so the follower just flopped around making a clicking noise.
TFLundyB275
PostPosted: Tue Nov 08, 2011 10:18 pm    Post subject: Re: CA PTO clicking Reply to specific post Reply with quote
looks like the only way Im going to figure this out is pulling the pump off and giving it a look see. The hydraulic pump works like it always have..so not sure if its going to be that. It did have a stuck valve on it when I first got it, but I fixed that...believe it was stuck because the trans oil was water contaminated for who knows how long. Perhaps it would be good if it was the pump..rather fix that then a broken gear or something.
TFLundyB275
PostPosted: Mon May 06, 2013 10:38 am    Post subject: Re: CA PTO clicking *problem found* Reply to specific post Reply with quote
I wanted to post an update for future reference.
I pulled the pump off today. It is indeed the same problem I "fixed" when I went over everything the first time. The pump has three plungers in a row starting from the front. The 4th/rearmost position is a valve. That valve is now stuck half way in, and it was stuck the first time around as well.
So the roller knocks against it making the tap/clicking sound with the pto/belt engaged.
The hydraulics still worked with no load which made questionable it was a pump problem without pulling it apart.
Fluid was new and clean hydtrans.
The valve in question was freed, cleaned and polished before reassembly the first time. Assembled nice, valve stuck again after approx. 2 hours of pto use.
Anyone know why this valve gets stuck?
