| Author |
Message |
Jason Hubner Regular
Posted: Thu Dec 01, 2011 5:56 pm Post subject: JD no. 5 mower |
I bought a JD no 5 mower this last summer. I'd like to put it behind my Case va to give me a reason to use the tractor. But are these mowers any good? Are they worth putting money into? The one i have needs some work to bring it up to snuff. |
| Back to top |
Nathan (SD) Regular
Joined: 17 Jun 2003 Posts: 301 Location: Day County, SD
Posted: Thu Dec 01, 2011 6:00 pm Post subject: Re: JD no. 5 mower |
If you are gonna use it a hour or 2 a year they are fine. Personally I used one for many years but had a bad run of pitman luck. Got a IH 120 and never missed the no.5. If you plan on going to JD for parts hang on to your wallet. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13487 Location: Coyote Flats,Tx
Posted: Fri Dec 02, 2011 4:31 am Post subject: Re: JD no. 5 mower |
| Nathan (SD) wrote: | | (quoted from post at 21:00:58 12/01/11) Got a IH 120 and never missed the no.5. If you plan on going to JD for parts hang on to your wallet. |
Nathan
IMHO all equipment parts are high $$$$$$$. I run JD,Ford & Kubota and they're all high. I doubt CIH is very cheap either. As far as a JD #5 mower they are good but OLD mowers. |
| Back to top |
NEKS Long Time User
Posted: Fri Dec 02, 2011 4:34 am Post subject: Re: JD no. 5 mower |
They are a good mower. For years used it to mow all my hay. Don't uses it much anymore, so after the last pitman rioted away take it off when done for the year and store in barn. |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6540 Location: Delta,colorado
Posted: Fri Dec 02, 2011 5:50 am Post subject: Re: JD no. 5 mower |
The #5 is one of the best older mowers out there.There are atill lots still being used,espeacially in the high-altitude mountain grass areas.They are pretty simple machines.They can be mounted on just about any tractor.My brother 'pulls his with a 560 IH.Afriend(in the mountains)runs two,each pulled by a Supert C.But they are "old"-1940s |
| Back to top |
Hotflashjr Tractor Expert
Posted: Fri Dec 02, 2011 7:25 am Post subject: Re: JD no. 5 mower |
I've got a No.5 on my JD MT tractor. About the same size/power tractor as your Case. It runs it good but I have spent a fair amount of money on it. I needed all new knives, had some broken parts, needed all new seals grease zerks, and gaskets and I needed to make my own PTO shaft to hook up to my tractor. So far I have about $350 into plus a fair amount of time. All restored I'd be lucky to get that for it. That being said, It looks great with my MT and I like working on it and using it. Very easy to work on with the owners manual and once you get it set up right, it mows well. |
| Back to top |
James Howell Tractor Guru
Joined: 06 Mar 2006 Posts: 5814 Location: Hutchins, TX
Posted: Fri Dec 02, 2011 8:08 am Post subject: Re: JD no. 5 mower |
We used a #5 mower to cut hay for several years and it worked very good.
We use it now to mow around trees and a few other areas and it works just fine.
Most of the "universal" parts, such as pitmans, knives, sections, rivets, are available at Tractor Supply.
There are several folks on the YT forum that also have OEM new and used parts.
Be sure to get an operators manual for your mower.
The manual is a great help in setting up the mower to cut/mow at its best.
The key is to "register" the knife correctly.
We've got several #5 mowers that are "working" mowers and one just for "show".
You can spend a lot of time and money on these old mowers, but if they serve your purpose then its time and money well spent.
Hope this helps and enjoy your John Deere #5 sickle mower. |
| Back to top |
glennster Tractor Guru
Posted: Fri Dec 02, 2011 9:27 am Post subject: Re: JD no. 5 mower |
i have a #5 also, good solid mower. mother deere still has alot of parts available, and also aftermarket suppliers too. but, the mower really works a lot better behind a RED tractor.
i have a marker cylinder off an 800 cyclo planter on this #5 to raise and lower the mower. beats the heck out of the manual lift.
Untitled URL Link
| Back to top |
Posted: Fri Dec 02, 2011 10:20 am Post subject: Re: JD no. 5 mower |
Any old John Deere mower will make a RED tractor worth more! |
| Back to top |
TomA Regular
| Back to top |
Leroy Tractor Guru
Joined: 09 Jan 1998 Posts: 9502 Location: Wapakoneta, Ohio
Posted: Fri Dec 02, 2011 10:35 am Post subject: Re: JD no. 5 mower |
I don't under stand all the pitman problems people have. Have used pitman mowers for years with some years 500+- acres a year and since I can remember and that is back to mid 50's and I bought my first mower in 1958-or 59 and have NEVER had a pitman break, something is wrong if they keep breaking pitmans. And for the sections all we ever had was rivits, bolts not yet out, and as long as they make rivits I will not atempt to use bolts. The ones that are complaining about the rivets are the ones that break more sections per 100 acres every year than we did on the 500 acres per year. And I have older mowers than that to restore for to go to the field. |
| Back to top |
Farmallb Long Time User
Posted: Fri Dec 02, 2011 11:17 am Post subject: Re: JD no. 5 mower |
#5s are the only tractor mower dad ever had. He had a IHC horse mower before that. That was it. Hed buy any good looking #5 he came across at sales. I think when he died he had the rmains of around 4 or 5, along with his good one, the one he used. It came with a foot lift, and unless my brother has thrown it away its still hanging in the tractor part of the grainery shed. I always wondered why a guy couldnt use one of the cult lifts on an A or B, run a length of loose cable to the mower, and raise it that way. He also mounted it on an A or 2 and a B, and an 48 H Farmall, and a 41 M |
| Back to top |
gtski Guest
Posted: Fri Dec 02, 2011 11:29 am Post subject: Re: JD no. 5 mower |
Glennster, You aint using that mower nearly enough. There's still too much paint on the guards and shoe. |
| Back to top |
Posted: Fri Dec 02, 2011 11:42 am Post subject: Re: JD no. 5 mower |
When we got our 43B it was set up to raise a mower with a cultivator lift as you mentioned above.
| Back to top |
fixerupper Tractor Guru
Joined: 12 Oct 2003 Posts: 7046 Location: Albert City Iowa
Posted: Fri Dec 02, 2011 11:46 am Post subject: Re: JD no. 5 mower |
Like everyone else said it's a good mower, otherwise Deere wouldn't have sold so many of them. A pitman breaks from either running it too fast, ground speed is too fast for the conditions or a worn or incorrectly set up cutter bar that pulls too hard. I suppose a worn, loose bearing on the drive end of the pitman could do it too.In other words, if the bar is chattering loud, even to the point where the drive train chatters, you're either going too fast, the hold downs need attention or the cutting edges on both the sickle sections and the ledger plates are worn. Some really fine grasses, like blue grass cut so hard you can't hardly go slow enough to prevent chatter and knocking. Jim |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
