| Author |
Message |
MikeS806/H Regular
Posted: Wed Dec 14, 2011 12:32 pm Post subject: Detroit diesel 453N timing gears |
working on a 453N detroit timing gears stripped on cam, balance shaft and blower, what would cause this problem? engine looks like it was rebuilt not long ago. |
| Back to top |
MikeS806/H Regular
Posted: Wed Dec 14, 2011 12:36 pm Post subject: Re: Detroit diesel 453N timing gears |
also where is a good place to find timing gears reasonable? I have the newer style fine tooth gears |
| Back to top |
NCWayne Tractor Expert
Posted: Wed Dec 14, 2011 12:42 pm Post subject: Re: Detroit diesel 453N timing gears |
I've rebuilt Detroits that had been in operation for 40 years and have never seen one strip the timing gears. Heck most of them didn't even show an appreciable amount of wear on the gears, much less being even close to being stripped. That said I can't think of anything off the top of my head that would have the power to hang anything in the timing up to the point that the gears would strip. I say that because to strip them something would have had to have brought the whole works to a screaching halt while the crank continued to turn long enough to strip them. Heck even a stop as violent and suddern of a stop as happens when something gets thrown into the blower and locks it up is more likely to twist off the blower drive shaft than it is to do anything else. Funny thing is that shaft is driven off of the same gearset your talking about so why wouldn't they even try to strip in that instance but do so in another?
If you ever figure out what did it please post back and let us know. You've definately got my curiousity up on this one. |
| Back to top |
VicS Tractor Expert
Posted: Wed Dec 14, 2011 1:52 pm Post subject: Re: Detroit diesel 453N timing gears |
I can't imagine them striping unless someone put in the old noisy gears or vice-versa. I have had my blower lock up, not enough end play. killed the motor. I have the number of a guy who has at least 50 of these gears. He is located in southern Il. Mt. Carmel Dick Walker 618 948 2714 . Vic |
| Back to top |
counterclockwise Regular
Joined: 13 Mar 2008 Posts: 103 Location: Central Michigan
Posted: Wed Dec 14, 2011 1:57 pm Post subject: Re: Detroit diesel 453N timing gears |
There is a 1900 Oliver with a 453 on ebay now. It is being sold piece by piece for parts. Two days left. Might want to watch it. |
| Back to top |
mite-help Regular
Posted: Wed Dec 14, 2011 2:17 pm Post subject: Re: Detroit diesel 453N timing gears |
New one--surely will have valve train/ piston contact damage also--I'd also like to know what happened---- |
| Back to top |
Bob Huntress Long Time User
Posted: Wed Dec 14, 2011 2:32 pm Post subject: Re: Detroit diesel 453N timing gears |
"what would cause this problem?"
Very bad lubrication, like none. I mean what does the oil pump look like? When they put the engine back together did they even put an oil pump in it? |
| Back to top |
MikeS806/H Regular
Posted: Wed Dec 14, 2011 2:52 pm Post subject: Re: Detroit diesel 453N timing gears |
I didnt take the oil pump apart, I removed a rod cap and the bearing looked great, the engine was very low on oil but with the bearing looking good it must of been getting some oil |
| Back to top |
MikeS806/H Regular
Posted: Wed Dec 14, 2011 2:53 pm Post subject: Re: Detroit diesel 453N timing gears |
yes there is some bent valves |
| Back to top |
Posted: Wed Dec 14, 2011 3:05 pm Post subject: Re: Detroit diesel 453N timing gears |
Based on the bearings lower being good, and the pressure being low, I'm guessing that either insufficient oil or a plugged gallery, as opposed to dirty or bad oil. Can you post pics of the wiped parts? |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23627 Location: in front of computer
Posted: Wed Dec 14, 2011 3:09 pm Post subject: Re: Detroit diesel 453N timing gears |
Either a runaway which whacked the valves into the pistons and locked the cam from rotating.
Or somebody mixed the old soft gears with the later hardened gears. |
| Back to top |
Jon Hagen Tractor Expert
Posted: Wed Dec 14, 2011 4:17 pm Post subject: Re: Detroit diesel 453N timing gears |
I had a 4-53 4 valve motor out of a truck that Broke rather than burned up the drive gears. The previous owner said they thought a bit of metal trash either from the valve gear or dumped in with the oil, went through that rear head drain hole and fell into the gears.
That explanation must have been right, as I replaced only the gears and the bent valves on 1 cylinder. Ran the engine trouble free for years after that. |
| Back to top |
MikeS806/H Regular
Posted: Wed Dec 14, 2011 4:39 pm Post subject: Re: Detroit diesel 453N timing gears |
just posted some pic"s |
| Back to top |
Posted: Wed Dec 14, 2011 6:01 pm Post subject: Re: Detroit diesel 453N timing gears |
Mike did you clean those parts up? |
| Back to top |
MikeS806/H Regular
Posted: Wed Dec 14, 2011 7:54 pm Post subject: Re: Detroit diesel 453N timing gears |
nope I didnt clean them, engine is very clean inside |
| Back to top |
