Long 610 - Air in fuel line
TBS11
PostPosted: Fri Dec 16, 2011 11:59 am    Post subject: Long 610 - Air in fuel line Reply to specific post Reply with quote
I have a Long 610 that we bought used. I had a problem a year or so ago with the fuel lines getting air in them. The fuel injector pump was leaking so I had it rebuilt and that seemed to solve the problem. Now a year later I am having the same problem. I try to start it and it will not fire up. You can tell it is not getting any fuel. I can bleed the fuel lines at the injectors and it will start. There is no diesel leaking that I can find. Has anyone else had this problem? Is there somewhere specific to look for a leak that is common to this tractor? Any advice or thoughts or welcome. Thanks.
Rich in IN
PostPosted: Mon Dec 19, 2011 8:40 am    Post subject: Re: Long 610 - Air in fuel line Reply to specific post Reply with quote
If you can, call me at 574 893 4172 after 7 PM any evening. I have some questions for you, also have some ideas for you to check out. I used to work for a Long dealer, and have repaired pumps and injectors since 1976.
Leaky Boot
PostPosted: Thu Dec 22, 2011 1:06 pm    Post subject: Re: Long 610 - Air in fuel line Reply to specific post Reply with quote
My 610 did same. If it sat more than a few days would have air. Seals in pump bad. New pump, about $700 to fix.
Post new topic    Yesterday's Tractors Forum Index -> Lesser Known Classics All times are GMT - 8 Hours
