| Author |
Message |
John Schoenauer Regular
Posted: Mon Dec 26, 2011 6:40 pm Post subject: Chain size |
I just bought a new gooseneck trailer and need to get chains to hold my tractor. I have looked at 5/16" rated at 4700 pounds and 3/8" rated at 6600 pounds. My tractor weighs about 5000 to 6000 pounds. I am not sure what size is required. Do I need 20' or will I be able to use 14' length?
Thanks for your time.
John Schoenauer |
| Back to top |
snoop-nc Long Time User
Posted: Mon Dec 26, 2011 8:37 pm Post subject: Re: Chain size |
John...it would be better...IMO...to go with the heavier chain. More than likely the 14 footer would be long enough. Why don't you take a tape measure and run it in/over/around like you would a chain and see what length you need? You gave us a weight estimate, but not what make/model tractor you are hauling.
Keep it safe!!
Rick |
| Back to top |
Randy Freshour Guest
Posted: Mon Dec 26, 2011 9:59 pm Post subject: Re: Chain size |
Go with the 3/8" Grade 70 chain. Make sure your binders are of equal or higher rating. The 14' length will probably work, but then the 20' will give you plenty of extra chain if you ever need more. |
| Back to top |
scotc Tractor Expert
Posted: Mon Dec 26, 2011 11:41 pm Post subject: Re: Chain size |
2 chains at 4700 WLL (working load limit) makes for 9400 combined WLL. Far more than is required for the weight. I'd get 4 of the 5/16 grade 70 (and make sure they are stamped with the grade, probably either "70" or "G7"). Last time I got some I painted a couple of the stamped links on each one.
I'd get a couple 14s and a couple 20s. If you decide the 20s are too long, depending on how long of a chain you need, you can cut them down and have more shorter chains. Just make sure any replacement clevises you put on them are also rated grade 70. 5/16 chains are a lot easier to deal with than 3/8 because of the weight, then there's the added cost. One 3/8 G70 chain also has more WLL than legally required to hold your tractor, so it's overkill.
5/16 chain uses the same binders as 3/8. I prefer lever binders, some prefer ratchet binders. The ratchet ones work good, but you have to keep them very well lubricated. And where I am, that would mean oiling them every time you got them out. |
| Back to top |
Paul from MN Regular
Posted: Tue Dec 27, 2011 6:39 am Post subject: Re: Chain size |
I use 20' 3/8 grade 70.
You could probably get by with 5/16, but with 3/8
there is no question that you have strong enough
chain, particularly if you ever haul a heavier
tractor.
I'd go with 20' because it gives you the ability
to haul other stuff where you might need a longer
chain. |
| Back to top |
caterpillar guy Long Time User
Posted: Tue Dec 27, 2011 8:17 am Post subject: Re: Chain size |
I buy 20ft 3/8 then cut them in half this gives plenty to tie down with and less to mess with left over. If you want to you can hook each end to the sides for the trailer. Then drop the middle over the drawbar. And hook the binders to the loop and each end, so the section in the middle hangs loose. |
| Back to top |
ericlb Tractor Guru
Posted: Tue Dec 27, 2011 12:28 pm Post subject: Re: Chain size |
go with the 20 foot 3/8 grade 70, youll pass any inspections, and someday your going to want to haul something larger than your tractor, you'll be glad you spent the money then |
| Back to top |
MikeinKy Long Time User
Posted: Tue Dec 27, 2011 5:13 pm Post subject: Re: Chain size |
I have spent a lot of years hauling steel and
machinery on a flat bed and have never used anything
except 5/16 grade 70 chain. 3/8 chain is very heavy
to handle. If 5/16 will hold 45000 lb coils it will
hold a tractor. I did use several chains. I never
broke a chain or lost a load. |
| Back to top |
charles todd Tractor Expert
Joined: 18 Jan 2008 Posts: 1807 Location: Northwest Louisiana
Posted: Tue Dec 27, 2011 5:15 pm Post subject: Re: Chain size |
Here is my take.
5/16" grade 70, 20 ft. Harbor Freight. The chain is stamped G70 and legit. Also ratcheting binders from the same store. I have 6 of each and can bind almost anything.
3/8" is overkill for about anything short of pulling stumps. Just my take.
CT |
| Back to top |
john in la Tractor Guru
Joined: 28 Mar 2004 Posts: 5889 Location: Bedico, La.
Posted: Wed Dec 28, 2011 5:10 pm Post subject: Re: Chain size |
You could use swing set chain if you wanted. You just need enough of it to hold the weight you are hauling.
3/8 is a pain because it is heavy. I would get some 5/16 and if you ever need to haul something real heavy just use extra chains.
A chain needs to be long enough to go from point A to point B. Only you can tell us how long that is.
The most important thing to remember is your chain and binders must be marked.
Lets take you 5/16 4700 lb chain. That is grade 70 transport chain. As long as you can still read the markings that tell you this is that type of chain you are good to 4700 lbs.
But lets say the tag falls off; the stamping gets rusted over or the paint fades.(depending on how it is marked) your 5/16 4700 lb chain is now only good for 1900 lbs grade 30 standards.
Even though your chain will hold much more if you can not prove what grade chain you have it will be considered grade 30. |
| Back to top |
Posted: Wed Dec 28, 2011 5:18 pm Post subject: Re: Chain size |
Thanks for the replies. The tractors I have are an 880 Oliver and a 77 Oliver with loader. Transport will mostly be from home to our farm. About the chain size (3/8 vs. 5/16) what do the DOT boys look for other that chain load rating. Do they compare load vs. rating, example for the 6000 # tractor does each chain need to be able to handle the load? I have talked to a DOT officer and he suggested that it would be good to use 4 separate chains instead of 2. I didn't ask about chain size. They gave me a book but I can't find anything about chain regulations.
Thanks again
John Schoenauer |
| Back to top |
Posted: Wed Dec 28, 2011 5:55 pm Post subject: Re: Chain size |
Chain laws are covered in DOT rules 393.100 to 393.136
I do not know your state laws so I will use federal laws.
Federal law says you need 2 chains for equipment less than 10,000 lbs. Some states say you need 4. Four seperate chains and binders is not a bad idea.
You need to tie down with a downward force of 20% of the weight. Just make the chains very tight and this will be covered.
You need to chain the rear to hold 0.8 g deceleration in the forward direction; This means you need 6000 lbs X .8 = 4800 lbs of chain on the rear. Two 4700 lb chains will be over kill. Heck 2 grade 70 1/4" chains rated at 3150 lbs would be enough.
You need to chain the front to hold 0.5 g acceleration in the rearward direction; and 0.5 g acceleration in a lateral direction.
That is 6000 lbs X .5 = 3000 lbs of chain rating.
One chain would be enough if you use 5/16 grade 70.
The trick with using 1 chain on each end is holding lateral movement.
So lets say you get 4 chains (5/16 grade 70) and binders. One on each corner. You now have 4700 lbs X 2 of hold down on each end (9400 lbs). You only need .8 on the rear so you could haul a tractor over 11,500 lbs with those 4 chains.
11,500 X .8 = 9200 lbs. |
| Back to top |
Posted: Wed Dec 28, 2011 5:57 pm Post subject: Re: Chain size |
Thanks, John in La. That info will be very helpful when I get ready to tie the tractor down.
John Schoenauer |
| Back to top |
Posted: Thu Dec 29, 2011 4:16 am Post subject: Re: Chain size |
This will help on chain sizes, and how much WLL you need pulling in each direction.
cargo securement handbook
| Back to top |
jddriver Long Time User
Posted: Thu Dec 29, 2011 3:52 pm Post subject: Re: Chain size |
Scot I agree with the 5/16 chain I haul steel and heavy machinery.I use only 5/16 chain.I have 8 on my trailer and that is a plenty for up to the 80000 net loads I haul.3/8 is too heavy to mess with |
| Back to top |
