Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Making Ramps for a trailer
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting
dmiller
PostPosted: Fri Dec 30, 2011 8:46 pm    Post subject: Making Ramps for a trailer Reply to specific post Reply with quote
Any input on ways to make or not make ramps. Trailer deck is 20 inches from the ground. 20 ft long. Never know what you will haul on a trailer but I do intend to use it to haul a 61 Chevy 3/4 ton and a JD A wide front with a loader (probably with a #5 mower attached sometimes).
Ideas, suggestions, or "don't do it this way"??? Main function of the trailer is small square hay bales so don't want to do anything that will impede that.
dmiller
PostPosted: Fri Dec 30, 2011 8:53 pm    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
here's the picture that should've been on the first message. Dial-up!!!
thebigyellowtruck
PostPosted: Fri Dec 30, 2011 9:21 pm    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
For my flatbed trailer there is a piece of 3/8" thick 4" wide angle iron that runs across the back. I bought a set of aluminum 8' long semi trailer car hauler ramps. I used grade 8 bolts to attach pieces of angle iron to each ramp so that the angle iron on the trailer and ramps interlock with each other. I load my AC WD on the trailer nicely with these ramps. They're also long enough so that I can use them for a small car too. Car hauler ramps should be able to handle almost anything you can throw at them.
scotc
PostPosted: Sat Dec 31, 2011 6:18 am    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
If you put on a set of flip-ups, you will have a tailboard for your idiot cubes. I'd make them long enough that you don't have more than about a 25 degree angle up them.
showcrop
PostPosted: Sat Dec 31, 2011 7:59 am    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
You can have a pair that I have for $100.00 They are about 4 1/2 ft long made of 3" angle stock will easily support 5,000 lbs.
dmiller
PostPosted: Sat Dec 31, 2011 10:05 am    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
How close are you to Billings Montana? I'm about 40 miles from there.
showcrop
PostPosted: Sun Jan 01, 2012 5:06 am    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
I am in southern NH. Just head out for a New Years Day drive!
charles todd
PostPosted: Sun Jan 01, 2012 6:51 am    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
I never thought about car hauler ramps... That is an idea!
CT
thebigyellowtruck
PostPosted: Sun Jan 01, 2012 10:25 pm    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
maybe this will help you to see how I use my ramps car hauler ramps with my trailer.
Photobucket
dmiller
PostPosted: Mon Jan 02, 2012 12:04 pm    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
The trailer came with a set almost like that, they now look more like a horshoe. The tractor was just too heavy for them???
Also I know giving loader rides is a bad idea, this was more of a photo op, than a ride.
I estimate the tractor, rear weights, and loader at around 8,000.
mkirsch
PostPosted: Thu Jan 05, 2012 7:34 am    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
In a word, overkill.
You've got a flat-deck trailer there with no beavertail, so your ramps have to be longer.
My recently-acquired trailer's ramps are framed out of 4" steel C-channel on edge, with heavy angle cross pieces. Even those are bent a little.
I need to make a center ramp for narrow front tractors, so I plan on replicating the original ramps.
caterpillar guy
PostPosted: Sat Jan 07, 2012 3:49 pm    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
You will need some sort of support for under the rear of the trailer or get a big surprise when you drive up your new ramps.
dmiller
PostPosted: Sat Jan 07, 2012 5:24 pm    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
I think I'm going to go with 6 feet long, made of 3 inch channel iron, 2 runners on each ramp with 2*2by 3/16 angle to make cross supports every 8 inches (by my estimate each ramp should be about 70 lbs). Make them attach with angle iron lips like a car hauler trailer and have a shelf for them under the deck when hauling. I think I'm going to go with a square tubing (reciever hitch type thing) that can be hooked up as an adjustable support on the rear corners. Time table has changed and something has come up so I will not get this done for about 2 weeks but will post pictures when done.
mkirsch
PostPosted: Mon Jan 09, 2012 6:50 am    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
On an 8000lb tractor, I don't think 3" channel is going to cut it over such a long distance. Please be careful when backing the tractor up on the first time.
caterpillar guy
PostPosted: Sun Jan 15, 2012 5:44 am    Post subject: Re: Making Ramps for a trailer Reply to specific post Reply with quote
I have 4" channel iron about 9-10" long for my stepdeck. It is about 38" high. They work great and will load a 1466 IH with out a problem. I have loaded backhoes and dozers(D-5 Cat) with them. If you do load tracked equipment throw a couple old tires on them for the tracks to bite on. If you are using standard weight 3" channel for 6" they will be plenty heavy for what you want to do.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
