| Author |
Message |
fastorange Guest
Posted: Sat Dec 31, 2011 4:01 pm Post subject: 3-53 Detroit puts out white smoke, warm or cold |
I bought a Clark Michigan 55 III wheel loader with the 3-53 Detroit engine.
It actually starts pretty well (50+, no ether, 49- small shot), but no matter how long you run it, it always has a lot of white smoke.
It has good power....
Anyone know what this is likely to be?
I am quite familiar with diesels, I just don't know this engine.
It does run on all cylinders from start up.
Thanks for any input. |
| Back to top |
greygoat Tractor Expert
Posted: Sun Jan 01, 2012 1:26 pm Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
As a retired Locomotive mechanic, my experiance
is on General Motors 16V645, locomotive engines,
which are V16, 645 cubic inch per cylinder,3000
horsepower,2 cycles, and are really, just, giant
Detroit Diesels. Before I offer advice, however,
I'll standby and see what opinions others offer! |
| Back to top |
cooop Regular
Posted: Sun Jan 01, 2012 4:31 pm Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
Because of the fact that it starts well, i dont think it would have worn rings. I would suggest that you check your airbox drains. make sure thoes drain tubes are kept open. Your blower seals could be leaking, causing it to ingest oil. or, if the smoke smells sweet, it could be burning antifreeze. If it is antifreeze, I would suspect it is leaking from the injector tubes in the head. Cooop |
| Back to top |
El Toro Tractor Guru
Posted: Mon Jan 02, 2012 4:17 am Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
We had one of those EMD V8 engine's in a mobile field dynamometer. Rated at 1600 hp and only turned 900rpm's. Hal |
| Back to top |
LJD Tractor Expert
Posted: Mon Jan 02, 2012 2:28 pm Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
I've got two big backhoe loaders with 3-53s. Both skip, sputter, and smoke when started at 50F - but clear up when warm.
Your problem sounds usual. If you get grey/white smoke when the engine is warm - and it runs smooth with no skipping- I'd suspect you're burning coolant. If so, I suspect you'll eventually notice the radiator doing down.
That being said - standard advice for any 2-stroke-cycle Jimmy that has valves (some don't) - adjust the rack. If the rack out, so is injection timing and fuel delivery. |
| Back to top |
fastorange Guest
Posted: Mon Jan 02, 2012 7:00 pm Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
It's not antifreeze, I guess I should have been more specific, it's just white un-burned diesel smoke... I don't know enough about these engines to diagnose them. It runs well enough, and doesn't burn much oil, so I don't think it's just to worn. It will run all day long with no problems except the smoke. I don't have a good Detroit mechanic around (as far as I can find out) or I would just have them come out and take a good look at it.
Thank you all for your help.
P.S. if it is worn out, does anyone have an idea of the material cost of an in-the-tractor overhaul on that engine? |
| Back to top |
fastorange Guest
Posted: Mon Jan 02, 2012 7:11 pm Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
Btw, is there any way to adjust the rack myself? I'm not familiar with two strokes, and I know every company makes different timing designs, although being Detroit it shouldn't be to complicated.
I also heard I would need special tools, are they something the average person can buy affordably?
Thanks again. |
| Back to top |
Averyman Regular
Posted: Tue Jan 03, 2012 12:11 pm Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
We have run a 4-53 in a tractor for many years, tough little engines. Start easily and smooth out quickly. Years ago we had a heavy downpour and unknown to me water got in through the exhaust. It still started right up but there was enough water on top of a piston to bend a rod. Still ran great with good power but smoked something like you describe due to lower compression in that cylinder. |
| Back to top |
cooop Regular
Posted: Tue Jan 03, 2012 2:55 pm Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
The only tool required to set the rack is a flat head screw driver. I presonally think that the rack is one of the hardest thing to do on a detroit. Basically, you set the fuel control tube arms so that each injector has the exact same rack position at any given time. I cant fully explain this procedure. If no one else posts the instructions, I would try to find some one who has a manual or some one who knows how to do this so you can learn. Once you understand what the directions are saying, it is not all that difficult. But, it is still one of the most difficult things to do. |
| Back to top |
LJD Tractor Expert
Posted: Tue Jan 03, 2012 6:36 pm Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
You just need one special and it's cheap - or at least they used to be. Used to cost $10 but haven't had to buy a new one in many years.
It is an injector height gauge.
Your Detroit has a fuel injector pump for each cylinder and each is activated by a rocker arm - just as the valves are. The "rack" is a general reference to the arms and linkage you have to adjust. With the injectors - you use a small gauge that sets the proper depth of each injector. Depending on the engine and the injectors used - the gauge you need can vary. if your engine is all original, your manual should give you the gauge number. If not -you can go by the number on the fuel-injector-pump.
If you can't get a gauge - you can get that height spec and make your own.
Gauge looks like this - and they very by height.
| Back to top |
VicS Tractor Expert
Posted: Tue Jan 03, 2012 7:22 pm Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
I also think you need to run your rack. First set your injector height, just like setting the valves on ether side of it. turn engine until one cylinder inj is down,just like the valves you are looking to set them all the way up. A Detroit tool is good but a caliper is ok. the height is 1.470,this is setting the timing, take your time set them all the same! again just like setting the valves, only you are measuring the height instead of the gap of the spring. Setting the rack is the hardest for me. Move throttle to wide open. Look for the shaft that has two screws on top to adjust. remember this rack must always move by-itself to idle. With the throttle wide open the back actuator can't hit the head bolt. I set this one first about 1/8 in from the head bolt. then adjust the next one exactly wide open, with the two screws on the shaft. then the front inj. Move the throttle back to idle. everything should be free. push it with your hand do they all start at once, do they all push their inj exactly wide open. This might take you a hour. don't be in a hurry. The best thing would to get a book! After you do this the idle speed will be different. Be sure the rack goes back to idle by itself! Have fun, you did check your valves. Vic |
| Back to top |
fastorange Guest
Posted: Thu Jan 05, 2012 7:31 am Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
Thank you all for your help! I'll try timing the rack, and let you all know how it went. I do have a couple of questions; where can I buy the timing tool?, and where should I look for a manual for my Clark Michigan 55 III wheel loader?, or should I get a manual for just the 353 engine?
Thank you again for your help. |
| Back to top |
LJD Tractor Expert
Posted: Thu Jan 05, 2012 11:46 am Post subject: Re: 3-53 Detroit puts out white smoke, warm or cold |
You can find the gauges many places. Snap On, Kent Moore, OTC, Ebay, Mac, etc. Prices at Mac or Snap On are ridiculous.
You need to know what injectors your 3-53 has to get the right gauge. All my 3-53s use a N45 gauge that sets them at 1.460". Costs $20 at:
http://www.dieselpro.com/dp-j1853kentmooretimingtoolfordetroitdieselinjector.aspx
Other places that sell gauges are . . .
I doubt the Michigan loader manual would have the info. You probably need a 53 series Detroit manual. I have one here somewhere. But even with the manual, you need to know what injectors are in there. When you pop off the valve cover, they well be marked.
http://www.ebay.com/itm/Kent-Moore-J-25558-Pin-Gauge-Detroit-Diesel-2-Cycle-53-71-92-Engines-/350493524499?pt=Pneumatic_Hydraulic_Valves_Parts&hash=item519b0ac213
http://buy1.snapon.com/catalog/item.asp?item_ID=73308&group_ID=1301
http://www.mactools.com/shoponline/product/tabid/120/p-318738--detroit-diesel-injector-gauge.aspx
http://www.costplustools.com/Kent-Moore-Tools-J-42665-INJECTOR-TIMING-GAUGE-803mm-for-Detroit_p_11452.html
http://www.ntxtools.com/network-tool-warehouse/OTC-J-42749.html |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
