| Author |
Message |
Shawry New User
Posted: Mon Jan 09, 2012 11:33 am Post subject: She stuck i think? |
Hi I have an old ford dexta which sadly dose not get lots of use and when i recently tried to start her the engine fails to turn even though the battery is fully charged, The starter will turn with no load? a friend seems to think that the engine has siezed ie the pistons are stuck any help would be greatful.
Regards Shawry |
| Back to top |
Super Trucker Regular
Posted: Mon Jan 09, 2012 4:29 pm Post subject: Re: She stuck i think? |
Check for stuck valves. A tap on the lifter to see if it moves. I've had a couple of tractors do this. Just a squirt of pb blaster and tap lightly untill loose |
| Back to top |
Shawry New User
Posted: Tue Jan 10, 2012 9:14 am Post subject: Re: She stuck i think? |
Thanks for the suggestion do i need to tap all valves or just the push rods and what sort of tap are we talking light i guess? will i be able to attempt turning engine with starter with the cover off the valves? |
| Back to top |
cdmn Regular
Posted: Wed Jan 11, 2012 4:34 pm Post subject: Re: She stuck i think? |
If the starter spins but doesn't turn the engine, it may just be a minor starter problem. The bendix may be dirty and stuck. Does the engine turn if you have the transmission in high gear and you roll the tractor a foot or so? (make sure the shut-off handle is pulled out, so it won't accidentally start and run over something.) If so, remove the starter and check the bendix. Maybe only cleaning it will free it up. Disconnect the battery before you do this, so you don't get sparking. You could also reach in thru the starter hole and pry on the flywheel teeth and see if it is stuck. If it is not actually stuck, you should be able to pull-start the Dexta with another tractor. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
