international feed mill model 1150
JMP
PostPosted: Fri Jan 13, 2012 6:08 pm    Post subject: international feed mill model 1150 Reply to specific post Reply with quote
going to look at a mill tommrow int. model 1150 any coments on these good or bad in my past only been around gehl model Thanks John
W.Brehm
PostPosted: Fri Jan 13, 2012 6:15 pm    Post subject: Re: international feed mill model 1150 Reply to specific post Reply with quote
First I think the IH's were made by Arts-Way. Check to make sure your hammers aren't wore out, auger flighting, augers, etc.
Brownie 450
PostPosted: Sat Jan 14, 2012 3:42 am    Post subject: Re: international feed mill model 1150 Reply to specific post Reply with quote
I would see/ hear it run at speed to check for vibration or imbalance. Make sure the bearings are good on the hammer mill shaft. Had a neighbor who had the front bearing go out. The drive pulley had to be cut off to get to the bearing.
I luv farmalls
PostPosted: Sat Jan 14, 2012 5:18 am    Post subject: Re: international feed mill model 1150 Reply to specific post Reply with quote
Just a note about the hammers,they can be rotated or switced around so that all four corners can be used.
jeramy
we have a 1150 used to grind ear corn every other week. have had it for about 15 years with little issues.ours likes to run fast when unloading or it makes a little noise in the gears
