| Author |
Message |
bordermen Regular
Joined: 12 Jan 2012 Posts: 29 Location: Rochester, NY
Posted: Sun Jan 15, 2012 7:08 am Post subject: Please Identify This Plow |
I just bought my first tractor, a Farmall A and it came with this plow. Can anyone identify it? I has these two sets of numbers on it: P022253 and P02559. It also came with the below brackets. Can someone please show me how to mount it to my A? Thanks!
| Back to top |
Athol Carr Long Time User
Joined: 30 Jul 2007 Posts: 509 Location: Chruistchurch, New Zealand
Posted: Sun Jan 15, 2012 12:45 pm Post subject: Re: Please Identify This Plow |
Looks like the standard single furrow plow for a Farmall A. It the long shank is because it is pulled from the mounting points behind the front axle, with shock-absorbing spring. It is lifted from the rear. I do not have a electronic version of the manual. IH Geelong (Australia) also used the same plow for the Farmall Super A with modifications to allow depth setting and lifting using the Touch-Control. In the US, the Farmall Super A used a new plow with shorter shank attached to the drawbar reversed under the back of the tractor, similar to that for the Farmall Cub |
| Back to top |
gtski Guest
Posted: Sun Jan 15, 2012 2:18 pm Post subject: Re: Please Identify This Plow |
Only thing i will add is to get the share, landslide and moldboard
derusted before you try using it. |
| Back to top |
bordermen Regular
Posted: Mon Jan 16, 2012 7:01 pm Post subject: Re: Please Identify This Plow |
still no takers on showing me how to hook this up? i think one of the brackets is part of the hand lift? am i right? |
| Back to top |
bordermen Regular
Posted: Wed Sep 12, 2012 3:54 am Post subject: Re: Please Identify This Plow |
does anyone have a diagram or book that shows how to hook it up and/or what bracket parts i need?
| athol carr wrote: | | (quoted from post at 13:45:45 01/15/12) Looks like the standard single furrow plow for a Farmall A. It the long shank is because it is pulled from the mounting points behind the front axle, with shock-absorbing spring. It is lifted from the rear. I do not have a electronic version of the manual. IH Geelong (Australia) also used the same plow for the Farmall Super A with modifications to allow depth setting and lifting using the Touch-Control. In the US, the Farmall Super A used a new plow with shorter shank attached to the drawbar reversed under the back of the tractor, similar to that for the Farmall Cub |
| Back to top |
bordermen Regular
Posted: Thu Sep 13, 2012 3:30 pm Post subject: Re: Please Identify This Plow |
anyone?
| gtski wrote: | (quoted from post at 15:18:26 01/15/12) Only thing i will add is to get the share, landslide and moldboard
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
