Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Wisconsin Generator/Distributor
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines
Ray Fregoe
PostPosted: Tue Feb 28, 2012 7:00 am    Post subject: Wisconsin Generator/Distributor Reply to specific post Reply with quote
Has anyone seen a 2 cyl. wisconsin engine with a generator in place of a magneto. The generator is a autolite and has a distributor attatched to the end of it. I've never seen one like this before. Is it better than a magneto.
greygoat
PostPosted: Tue Feb 28, 2012 7:23 am    Post subject: Re: Wisconsin Generator/Distributor Reply to specific post Reply with quote
2 and 4 cylinder engines were available with
that option. Usually electric start models
that had a battery that needed charging, and
had coil ignition. Distributors were "Autolite"
and i've tried to find caps and rotors from
auto parts stores, but told "No longer available"
There are some distributor caps right now on EBay
but i'm going to have to reserch the parts books,
any anyway the sellers must think they're gold!
JOB
PostPosted: Tue Feb 28, 2012 11:50 am    Post subject: Re: Wisconsin Generator/Distributor Reply to specific post Reply with quote
I went to the Wisconsin distributor in MN. and was told the same thing. Even he can not get them from Wisconsin.
He can't even get points and condenser.
If you find some would you pass along your source.
retired wrench
PostPosted: Sun Mar 04, 2012 6:16 am    Post subject: Re: Wisconsin Generator/Distributor Reply to specific post Reply with quote
A dist is much better than a mag. The mag would break down when it got hot and the engine wouldnt start.That is why you saw them left running thru dinner.With a dist they would start with a half turn any time.
LJD
PostPosted: Wed Mar 07, 2012 1:12 pm    Post subject: Parts ARE available no problem Reply to specific post Reply with quote
I've got several Wisconsin powered tractors with that Autolite/Prestolite distributor. Yes, it's better then a magneto. Has more potential spark energy and easier to work on.
Don't believe the stories about parts not being available. Cap, rotor, points and condensor easy to get - even at your local NAPA. Same parts use in many old tractors, boats, cars, and motorcycles (Crosley, Indian, Waukesha,etc.).
The old Autolite numbers change to Prestolite and NAPA sells them with Echlin numbers.
Cap is NAPA AL143 for $20
Rotor is NAPA AL32 for $12.50
Points are NAPA AL5661 for $11
Condensor is AL38 for $11 or the HD condensor AL116 for $16
Brian Dan
PostPosted: Mon Mar 12, 2012 2:59 pm    Post subject: Re: Wisconsin Generator/Distributor Reply to specific post Reply with quote
Wisconsin engines had two types of ignition systems. 1. Battery Igition 2. Magneto Ignition. They both have a distributor.
Both are good. Magneto ignition was and still is a good system. No battery needed. The reason most of the old engines would not start was from vapor lock. Those old engines on bailers and combines were so dirty that they could not cool off. I have a magneto on my wisconsin engine that runs my wood splitter. It always starts when it is hot or cold.
Brian
LJD
PostPosted: Tue Mar 13, 2012 11:30 am    Post subject: Re: Wisconsin Generator/Distributor Reply to specific post Reply with quote
Wisconsin used at least four basic systems. Remote/stand-alone magneto-breaker-point with an impulse-spring for starting, flywheel magneto with breaker-points, capacitive-discharge breakerless flywheel magneto with separate remote mount coil, and battery-coil ignition.
Battery coil ignition offers the most spark energy when needed. Up to 40,000 volts. All the others max at half-that at around 20,000 volts.
Many old engines did start hard from vapor lock - but many also had starting problems due to bad points, dead condensor, broken impulse, and/or weak magnets in the magneto.
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines All times are GMT - 8 Hours
