| Author |
Message |
pgarrett Guest
Posted: Wed Mar 07, 2012 1:01 pm Post subject: H axle bearing |
Do you guys have a source for the outer,rear axle bearing for an H? They are $115 from the dealer. |
| Back to top |
rustyfarmall Tractor Guru
Joined: 07 Feb 2003 Posts: 18506 Location: Southwest Iowa
Posted: Wed Mar 07, 2012 1:12 pm Post subject: Re: H axle bearing |
| pgarrett wrote: | | (quoted from post at 14:01:37 03/07/12) Do you guys have a source for the outer,rear axle bearing for an H? They are $115 from the dealer. |
That price probably is not too far off. Bearings and oil seals are priced according to the popularity of the application. The fewer the applications, the higher the price. The cost for setting up to produce a bearing is the same whether it is a run of several thousand pieces or just 100.
Shop around a bit. You might be able to knock $20 or $30 off the price, but if you find one priced considerably below that, question the quality.
I wouldn't be afraid of a NICE used bearing either. |
| Back to top |
kevinj54 Long Time User
Joined: 04 Mar 2008 Posts: 567 Location: West Michigan
Posted: Wed Mar 07, 2012 1:25 pm Post subject: Re: H axle bearing |
| pgarrett wrote: | | (quoted from post at 17:01:37 03/07/12) Do you guys have a source for the outer,rear axle bearing for an H? They are $115 from the dealer. |
Take it to your local PT house and get it priced. |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Wed Mar 07, 2012 1:27 pm Post subject: Re: H axle bearing |
I have 12 axle assemblies from Hs I have parted out. I have taken one apart to weigh the parts to see if they would be mailable and I also found that the bearings seemed to be good and tight. I'd be happy to sell a bearing for $10 plus postage if a used bearing is a possibility for you. I know I can ship for $6 in a flat rate envelope, might be cheaper another way depending where you are located.
Zach |
| Back to top |
Posted: Wed Mar 07, 2012 1:28 pm Post subject: Re: H axle bearing |
Part number is 43719D, or ST252. I'm sure it is a Timken, but I do not have a source. |
| Back to top |
randy hall Long Time User
Posted: Wed Mar 07, 2012 2:07 pm Post subject: Re: H axle bearing |
according to my ih bearing book a st252 is a 213-ZJ |
| Back to top |
Jason the Red Long Time User
Joined: 12 May 2009 Posts: 714 Location: Grain Valley MO
Posted: Wed Mar 07, 2012 6:07 pm Post subject: Re: H axle bearing |
I bought a used one such as what Zach has. That bearing is quite expensive, $98 at my local Case/ IH and $118 at my local parts house. I found the used one that was in great shape locally for $20. |
| Back to top |
CNKS Tractor Guru
Posted: Wed Mar 07, 2012 6:57 pm Post subject: Re: H axle bearing |
$115 from CaseIH is not a bad price at all. |
| Back to top |
richardinnz Regular
Posted: Thu Mar 08, 2012 2:17 am Post subject: Re: H axle bearing |
All the transmission bearings in an H are standard metric ball bearings. Just get your local bearing supplier to measure it up. I completly replaced ALL the bearings and seals in my transmission exept for the roller bearing inside the top gear coupler for around NZ$400.00. The outer axle bearings I think were 6014 bearings from memory. I was really suprised to find metric bearings in a 1944 American tractor. |
| Back to top |
pgarrett Guest
Posted: Thu Mar 08, 2012 5:35 am Post subject: Re: H axle bearing |
Zachary-I would buy a couple of those bearings. E-mail me your phone no. pgarrett@aljmueller.com |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5375 Location: SE Wisconsin
Posted: Thu Mar 08, 2012 6:34 am Post subject: Re: H axle bearing |
| CNKS wrote: | | (quoted from post at 19:57:31 03/07/12) $115 from CaseIH is not a bad price at all. |
I agree. I thought mine were twice that from CNH. I got mine from a local bearing store for half the price of CNH. |
| Back to top |
Posted: Thu Mar 08, 2012 10:21 am Post subject: Re: H axle bearing |
Email on the way.
Zach |
| Back to top |
Rework New User
Posted: Mon Nov 26, 2012 8:30 am Post subject: Re: H axle bearing |
| Zachary Hoyt wrote: | (quoted from post at 14:27:35 03/07/12) I have 12 axle assemblies from Hs I have parted out. I have taken one apart to weigh the parts to see if they would be mailable and I also found that the bearings seemed to be good and tight. I'd be happy to sell a bearing for $10 plus postage if a used bearing is a possibility for you. I know I can ship for $6 in a flat rate envelope, might be cheaper another way depending where you are located.
Zach |
Hello Sir: If you still have some used "H" outer bearings, I am very interested. The old one I removed was a ND 1213R with one shield on the inside, and no grease groove. Seems to me this this was installed incorrectly. Shouldn't the shield be on the outside, especially if the lubrication is via the transmission grease? Why wouldn't one seal be better?
My email is "dekruse@huntel.net".
Thank you,
Rework |
| Back to top |
