| Author |
Message |
njfarmer New User
Posted: Tue Apr 03, 2012 6:07 pm Post subject: Gooseneck Hitch |
I would like to put a gooseneck hitch onto my 1999 ford f350 and am looking for suggestions on which brand of hitch to put on. I don't have to worry about the bed being in the way because it is already off of the truck to undercoat the frame so a ridged frame one would work. Any Suggestions? |
| Back to top |
S2710 Long Time User
Joined: 08 May 2008 Posts: 948 Location: West central Wisconsin
Posted: Tue Apr 03, 2012 6:38 pm Post subject: Re: Gooseneck Hitch |
I would go with the B W turn a ball.
poke here
| Back to top |
rustyfarmall Tractor Guru
Joined: 07 Feb 2003 Posts: 18497 Location: Southwest Iowa
Posted: Wed Apr 04, 2012 4:49 am Post subject: Re: Gooseneck Hitch |
| S2710 wrote: | (quoted from post at 19:38:45 04/03/12) I would go with the B W turn a ball.
poke here
I'll second that motion! |
| Back to top |
PJH Tractor Expert
Posted: Wed Apr 04, 2012 9:45 am Post subject: Re: Gooseneck Hitch |
One of our local farm stores was selling these type of hitch plates for around $100. I'm assuming your F-350 is a flatbed.
Hitch plate
| Back to top |
Posted: Wed Apr 04, 2012 10:16 am Post subject: Re: Gooseneck Hitch |
| PJH wrote: | (quoted from post at 10:45:39 04/04/12) One of our local farm stores was selling these type of hitch plates for around $100. I'm assuming your F-350 is a flatbed.
Hitch plate
Is that one of those that simply bolts to the bed of the pickup box? A TRUE gooseneck hitch bolts to the FRAME. No way would I use one of those plates. |
| Back to top |
mkirsch Tractor Guru
Posted: Wed Apr 04, 2012 11:05 am Post subject: Re: Gooseneck Hitch |
It's gotta bolt THROUGH the bed to the frame or UNDER the bed, I'd think.
Only an idiot would bolt a gooseneck to the bed. It would tear out of there the first time you hooked to anything. |
| Back to top |
G. Fields Regular
Posted: Wed Apr 04, 2012 2:59 pm Post subject: Re: Gooseneck Hitch |
B&W turn over ball! |
| Back to top |
State of Jefferson Long Time User
Posted: Thu Apr 05, 2012 7:51 am Post subject: Re: Gooseneck Hitch |
I've made several of my own. 8"x3/4" plate bolted to 1/2" angle iron, bolted to the frame. Drill hole in center of plate for shank of ball, nut welded to bottom of plate, use a pipe wrench to take ball on and off.
That being said, if I were gonna buy one, I'd go B&W.
Ben |
| Back to top |
PJH Tractor Expert
Posted: Thu Apr 05, 2012 5:43 pm Post subject: Re: Gooseneck Hitch |
I guess you could mount it any way you wanted to, but anyone with any sense would bolt it directly to the frame. I certainly wouldn't want anything but a true gooseneck hitch. . . |
| Back to top |
Posted: Fri Apr 06, 2012 5:07 am Post subject: Re: Gooseneck Hitch |
What's a "true gooseneck hitch" in your eyes?
For decades, people were just laying a 3/4" to 1" flat plate of steel across the frame rails on their truck, welding it down, punching a hole in the middle, and installing a ball.
That is a TRUE gooseneck hitch. These no-drill hide-a-ball things didn't come along until about 15 years ago. |
| Back to top |
Pitalplace Regular
Joined: 09 Feb 2006 Posts: 353 Location: North Platte, NE
Posted: Fri Apr 06, 2012 5:39 am Post subject: Re: Gooseneck Hitch |
| mkirsch wrote: | (quoted from post at 08:07:52 04/06/12) What's a "true gooseneck hitch" in your eyes?
I have to laugh Did several this way years ago and just welded the ball to the plate. |
| Back to top |
chevytaHOE5674 Long Time User
Joined: 19 Mar 2009 Posts: 1397 Location: Western UP, Mi
Posted: Fri Apr 06, 2012 5:46 am Post subject: Re: Gooseneck Hitch |
For decades, people were just laying a 3/4" to 1" flat plate of steel across the frame rails on their truck, welding it down, punching a hole in the middle, and installing a ball. |
My GN hitch is an 10" piece of 1/2" thick channel iron welded between the frame rails. Gets the job done and has hauled many a heavy load. |
| Back to top |
J.Wondergem Tractor Expert
Joined: 05 Mar 2009 Posts: 2009 Location: Rockford, Mi
Posted: Fri Apr 06, 2012 6:37 am Post subject: Re: Gooseneck Hitch |
I have a "Hiddin Hitch in one, and a "B&W" turn a ball, in the other. I prefer the "B&W". |
| Back to top |
Posted: Fri Apr 06, 2012 1:10 pm Post subject: Re: Gooseneck Hitch |
The way I looked at it when I bought the B&W, was that IF the hitch failed for whatever reason, and somebody got hurt because of that failure, I wanted to be able to say "I didn't build it". |
| Back to top |
Ralph Bauer Tractor Expert
Joined: 10 May 2011 Posts: 1555 Location: Greer County, Oklahoma
Posted: Fri Apr 06, 2012 10:49 pm Post subject: Re: Gooseneck Hitch |
How do you tell the "max load" on a hide-a-way hitch... just curious, have one too but never pulled anything of sizable weight with it. |
| Back to top |
