crankshaft pulley removal
rich o
PostPosted: Fri Apr 06, 2012 6:04 pm    Post subject: crankshaft pulley removal Reply to specific post Reply with quote
any tips on removing the crankshaft pulley from my massey 65, when i try to break the nut , the crank turns as well, were would i stabilize the shaft to remove the nut?
JMS/.MN
PostPosted: Fri Apr 06, 2012 7:41 pm    Post subject: Re: crankshaft pulley removal Reply to specific post Reply with quote
Is there room to get in with an impact wrench?
rich o
PostPosted: Sat Apr 07, 2012 3:24 am    Post subject: Re: crankshaft pulley removal Reply to specific post Reply with quote
yes block is nearly stripped down, just when i try to remove bolt ,the crankshaft spins as well, were would i 'wedge' something to stop rotation of shaft. i see some small bore holes in the fly wheel that could possibly do the trick but i wanted to know how the experts do it
greygoat
PostPosted: Sat Apr 07, 2012 7:12 am    Post subject: Re: crankshaft pulley removal Reply to specific post Reply with quote
Any time I've tried to take that nut off, I've
put the transmission into gear!
El Toro
PostPosted: Sat Apr 07, 2012 7:34 am    Post subject: Re: crankshaft pulley removal Reply to specific post Reply with quote
Use a 6 point socket and an air impact wrench that's been mentioned. Use a 3/4 impact if you have one. Hal
PS: Make sure you're turning it CCW to loosen.
Jerry/MT
PostPosted: Sat Apr 07, 2012 9:08 am    Post subject: Re: crankshaft pulley removal Reply to specific post Reply with quote
Put the tractor in gear and then use a puller on the pulley after you remove the nut.
showcrop
PostPosted: Sat Apr 07, 2012 9:14 am    Post subject: Re: crankshaft pulley removal Reply to specific post Reply with quote
I have put a long wrench on it and then hit the other end of the wrench with a hammer.
El Toro
PostPosted: Sun Apr 08, 2012 5:22 am    Post subject: Re: crankshaft pulley removal Reply to specific post Reply with quote
Use a piece of oak to jam the crankshaft from turning. Then use an air impact to loosen the nut. Hal
JOHNNYfromMI
PostPosted: Sun Apr 08, 2012 11:01 am    Post subject: Re: crankshaft pulley removal Reply to specific post Reply with quote
Some have left hand threads!
MFJohn
PostPosted: Mon Apr 09, 2012 3:20 am    Post subject: Re: crankshaft pulley removal Reply to specific post Reply with quote
If you"ve pulled the oil pan, jam a 2 by 4 between the crankshaft and the block so it can"t turn.
