| Author |
Message |
awhtx Tractor Guru
Joined: 16 Jan 2002 Posts: 5048 Location: Lampasas, TX
Posted: Thu May 17, 2012 2:04 pm Post subject: 4 Cylinder Engine Block Casting/Engineering Codes |
I have three 4 cylinder Diesel blocks out in the shop. All have 3.90" bores so they are 172's- not 144's.
Note: All of these have Sleeves and Cannister style oil filters.
310609 cast June 19, 1958 (86T date code). No crankshaft balancer and no teeth on the crank to drive a balancer.
B9NN6015B cast March 10, 1960 (0C10 date code).
C0NN6015C cast September 29, 1960 (0J29 date code).
I had a C0NN6015? block with no sleeves and a spin-on filter but I must have sold it because it's not here now. |
| Back to top |
souNdguy Tractor Guru
Posted: Thu May 17, 2012 3:15 pm Post subject: Re: 4 Cylinder Engine Block Casting/Engineering Codes |
hows the weather over there man? getting any rain? |
| Back to top |
LaneVA New User
Posted: Fri May 18, 2012 3:18 am Post subject: Re: 4 Cylinder Engine Block Casting/Engineering Codes |
The blocks here are:
EAF6015J, 73F, 3.90", Sleeves, Gas, 172
C0NN6015J, 3F27, 3.90", No Sleeves, Gas, 172, Industrial
C0NN6015J, 6E4, 3.90", No Sleeves, Diesel, 172, Balancer
310905, 91G, 3.44", Sleeves, Gas, 134
C0NN6015G, 2M26, 3.44", No Sleeves, Gas, 134
C0NN6015G, 3C12, 3.44", No Sleeves, Gas, 134 |
| Back to top |
awhtx Tractor Guru
Posted: Fri May 18, 2012 4:13 pm Post subject: Re: 4 Cylinder Engine Block Casting/Engineering Codes |
Your C0NN6015J diesel with the 6E4 date code translates to 1966, May, 4th (possibly 1976?) so I'm guessing it must have been a Service Replacement (parts counter) or Industrial block. |
| Back to top |
LaneVA New User
Posted: Sat May 19, 2012 3:02 am Post subject: Re: 4 Cylinder Engine Block Casting/Engineering Codes |
Yes, I removed the diesel engine from a 1959 tractor and the head had a 1959 date code so the block had been replaced. |
| Back to top |
10 bluebird New User
Posted: Thu Dec 27, 2012 5:18 am Post subject: Re: 4 Cylinder Engine Block Casting/Engineering Codes |
| awhtx wrote: | (quoted from post at 15:04:33 05/17/12) I have three 4 cylinder Diesel blocks out in the shop. All have 3.90" bores so they are 172's- not 144's.
I need a B9NN6015B block. |
| Back to top |
NWMO 901 SOS Long Time User
Joined: 24 Nov 2006 Posts: 1385 Location: St. Joseph, MO
Posted: Thu Dec 27, 2012 10:05 am Post subject: Re: 4 Cylinder Engine Block Casting/Engineering Codes |
| 10 bluebird wrote: | (quoted from post at 08:18:33 12/27/12) | awhtx wrote: | (quoted from post at 15:04:33 05/17/12) I have three 4 cylinder Diesel blocks out in the shop. All have 3.90" bores so they are 172's- not 144's.
Seems like you've found one, and Alan is a respected member/contributor here.
Chris |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
