Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
$$ to overhaul SCV??
Post new topic    Yesterday's Tractors Forum Index -> John Deere
Roger in Iowa
PostPosted: Sat May 19, 2012 10:48 am    Post subject: $$ to overhaul SCV?? Reply to specific post Reply with quote
SCV on my 1971 leaks high pressure to marker cylinder on 7000 planter. Have to hold lever activated down to prevent marker from raising while planting.
How much is it going to cost me? Poppets, seats, etc, and labor (will vary I understand). Looking for ball park $$.
Thanks,
JMS/.MN
PostPosted: Sat May 19, 2012 1:56 pm    Post subject: Re: $$ to overhaul SCV?? Reply to specific post Reply with quote
Seems like the kit, maybe with cage, was around $100 a few years ago. Have you tried it in float?
jared in wi
PostPosted: Sat May 19, 2012 6:20 pm    Post subject: Re: $$ to overhaul SCV?? Reply to specific post Reply with quote
Poppets are around $50 a piece. Seal kit is about $50 as well. Four puppets are needed and one seal kit. Approx. $250 in parts, and the labor will vary, but will range from $250 to $350. Additional parts will vary depending on what is found once it is disassembled. Total bill should be around $600. Where are you located, I have many years of experience reconditioning these. Email is open if you have any additional questions.
Tx Jim
PostPosted: Sun May 20, 2012 3:30 am    Post subject: Re: $$ to overhaul SCV?? Reply to specific post Reply with quote
Roger
Have you tried reversing the hose to the other side of same SCV?
RE10924 KIT, SCV OVERHAUL ADD 49.09 USD
AR86535 VALVE, POPPET ASSEMBLY ADD 52.00 USD 208.00 USD
R65501 SPRING ADD 2.95 USD 11.80 USD
*Total 268.89 USD
Roger in Iowa
PostPosted: Sun May 20, 2012 9:23 am    Post subject: Re: $$ to overhaul SCV?? Reply to specific post Reply with quote
Yes, I have tried the other side of the SCV. Other SCV has the same problem but double acting cylinder and larger on the lift of the planter doesn't cause as much of a problem.
No float position as mentioned as a solution. Is SCV linkage mis-adjusted. Or do they all not have float position.
2nd SCV is not original to the 3020.
THX
Mike Aylward
PostPosted: Sun May 20, 2012 11:06 am    Post subject: Re: $$ to overhaul SCV?? Reply to specific post Reply with quote
Roger, there is a float position available on these tractors (and the older ones as well). Place the linkage rod at the SCV in the other hole, then place your lever fully forward. Mike
Tx Jim
PostPosted: Sun May 20, 2012 11:36 am    Post subject: Re: $$ to overhaul SCV?? Reply to specific post Reply with quote
Roger in Iowa wrote:
(quoted from post at 13:23:04 05/20/12)
Roger it's been several years since I sold/service 3020/4020 tractors but I think if you remove parts key #13 you can put SCV in float on a '71 3020
Mike Aylward
PostPosted: Sun May 20, 2012 12:45 pm    Post subject: Re: $$ to overhaul SCV?? Reply to specific post Reply with quote
Jim, I believe no. 13 is a rubber piece that locks the lever in place, such as using a hydraulic motor or a separate loader valve. It has no function on the float. This is done at the linkage of the SCV. Mike
Tx Jim
PostPosted: Sun May 20, 2012 4:18 pm    Post subject: Re: $$ to overhaul SCV?? Reply to specific post Reply with quote
Mike
You're correct thanks for correcting me. Oldtimers disease(CRS) got me again
