Air Compressor motor smoked...
dave404
PostPosted: Tue May 22, 2012 4:03 am    Post subject: Air Compressor motor smoked... Reply to specific post Reply with quote
well guys, everything was going great yesterday, got my 600 fenders and hood ready to spray the finish coat. Got all but the backsides done and Bam ! smoke rolled from my compressor motor.
compressor is about 2yr old ,used very little
cambell hausfield 2stage with a 5hp Magnetec Century 22amp motor.
We took the motor apart and the copper windings in one spot are toast.
What would cause such sudden failure as this, compressor was running when the smoking started and i shut it down quickly.
like i said, this compressor is like new and used very little.
Stephen Newell
PostPosted: Wed May 23, 2012 4:39 am    Post subject: Re: Air Compressor motor smoked... Reply to specific post Reply with quote
If you had sufficient electricity I would say the motor was just defective. I've never had very good luck with Campbell Hausfield. I think Chicago Electric is better quality.
Motorcraftman
PostPosted: Wed May 23, 2012 10:17 am    Post subject: Re: Air Compressor motor smoked... Reply to specific post Reply with quote
I Think..Simply it was a FACTORY Defect... That sadly only showed up after the warranty was out... That happens to me Occasionally... on something Rarely used.. It's a Bummer i know! Larry KF4LKU
Red Ford
PostPosted: Fri May 25, 2012 3:17 pm    Post subject: Re: Air Compressor motor smoked... Reply to specific post Reply with quote
Various possible causes, but the reason the motor failed was due to either overheating, or a defect.
dave404
PostPosted: Fri May 25, 2012 6:04 pm    Post subject: Re: Air Compressor motor smoked... Reply to specific post Reply with quote
thanks, must of been a weak point in the winding, we were only using it to prime some tractor parts, it only kicked on a couple times while using it.
went to tsc and picked up a marathon 6hp 23 amp for 229.00 plus tax.
we took the smoked motor apart and the copper windings at the rear were burnt about 1-2"
GordoSD
PostPosted: Fri Jun 01, 2012 6:55 pm    Post subject: Re: Air Compressor motor smoked... Reply to specific post Reply with quote
Agree, defect. I came home the other day and my CH 60 gal was running. Went over to see what was going on. Motor, compressor and tank were ALL too hot to touch. Pressure showed 60 lbs. God knows how long it was running. Pulled the plug.
Next morning I plugged it in, it ran up to 125 and shut down as normal.
Lesson learned though, I'll never leave it "ON" or plugged in when not using again.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
