2030 brake problem
tenn.
PostPosted: Thu May 24, 2012 3:08 am    Post subject: 2030 brake problem Reply to specific post Reply with quote
i have a jd 2030 i have to pump the brakes one time before they catch, could someone tell me how to go about fixing this.
Cliff Nelson
PostPosted: Thu May 24, 2012 4:47 am    Post subject: Re: 2030 brake problem Reply to specific post Reply with quote
Have you tried bleeding them? There is a bleeder fitting on the top of the axle housing flange. Try that first. If the problem continues it is the o-rings/ square packings on the brake pistons leaking letting air into the brake system. This requires removing the axle housing to replace the o-rings.
Tx Jim
PostPosted: Thu May 24, 2012 8:27 am    Post subject: Re: 2030 brake problem Reply to specific post Reply with quote
I second bleeding brakes first but required pumping could be caused from leaking valves in the brake valve housing. If brake pedals are locked together is pumping still required????
tenn.
PostPosted: Thu May 24, 2012 2:04 pm    Post subject: Re: 2030 brake problem Reply to specific post Reply with quote
yes it will still do it with them locked,whats this mean
Tx Jim
PostPosted: Thu May 24, 2012 2:28 pm    Post subject: Re: 2030 brake problem Reply to specific post Reply with quote
tenn
That's a test to see if the equalizer valve in master cyl is at fault but it isn't.
tenn.
PostPosted: Thu May 24, 2012 4:58 pm    Post subject: Re: 2030 brake problem Reply to specific post Reply with quote
thanks for the information , i bled the brakes and that did the job. i didn't know that was the bleeder fitting .
