Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
D3B Oil Leak
Post new topic    Yesterday's Tractors Forum Index -> Crawlers, Dozers, Loaders and Backhoes
G B Johnson
PostPosted: Fri May 25, 2012 6:01 pm    Post subject: D3B Oil Leak Reply to specific post Reply with quote
I have an oil leak on the engine block between the injector pump and the govenor, behind the booster fuel pump. The oil is not comming from the booster pump. The oil drips onto the motor support below. I have an oil leak around the throttle control shaft but I believe there is more oil comming from somewhere else. To replace the seal around the throttle shaft I need to remove the plate on the govenor held on by six bolts. Will things fly apart if I remove the plate to replace the seal? Any ideas where the other oil may be comming from?
Thanks,
G B
D3B
PostPosted: Fri May 25, 2012 10:54 pm    Post subject: Re: D3B Oil Leak Reply to specific post Reply with quote
If it's leaking from the throttle shaft, Bob/Ont told me the best fix. Take the cover off carefully so nothing pops out of place (it shouldn't) and put two new seals in instead of one. That's what I did on my 931B that was leaking because the seal got hard. I put a couple drops of oil in between the two seals just to provide a little lubrication for the outside seal. It's possible all the oil is coming from the throttle shaft.
G B Johnson
PostPosted: Sun May 27, 2012 7:09 am    Post subject: Re: D3B Oil Leak Reply to specific post Reply with quote
Thanks, I will get another seal. I assume that the plate is thick enough to hold two seals.
I hope that is where all of the oil is comming from. I have lost contact with Bob/Ont. Is he still active on the forum?
I had another posting on a water leak. Do you have any advice on fixing the water leak between the timing gear cover and the head?
G B
D3B
PostPosted: Sun May 27, 2012 7:47 am    Post subject: Re: D3B Oil Leak Reply to specific post Reply with quote
Bob responded to you above in another post. Yes, the cover will hold two seals. You have to get the seal from Cat and if I remember they're about $9 each. Bob is the best one to talk to though. The place that rebuilt my engine told me I need to have the injection pump rebuilt because of the oil leak on the throttle shaft. Good thing I asked and Bob responded. He's been a great help with my Cat.
