| Author |
Message |
dubv Regular
Posted: Tue May 29, 2012 3:13 pm Post subject: Allis Chalmers 444 Square Baler knotters |
I have a Allis 444 square baler that had the knotter frame and bill hook go on me yesterday. I have been told that the knotters on the 444 are New Holland knotters...is this true, and if so, what era New Holland baler would have the same knotters? I know they are the "Deering" style, etc, but are they exactly the same?
Also, if not, anyone know of any parts sources for used knotters on the AC square balers?
Thanks in advance! |
| Back to top |
Dick2 Tractor Guru
Posted: Tue May 29, 2012 4:12 pm Post subject: Re: Allis Chalmers 444 Square Baler knotters |
My AC book says that the model 444 was made during 1970 and 1971. It is the same as the model 443, except that it has a 3-joint driveline. |
| Back to top |
gtski Guest
Posted: Tue May 29, 2012 7:19 pm Post subject: Re: Allis Chalmers 444 Square Baler knotters |
New Holland 315 maybe more but sure of 315. Some Deeres are the same too. 336?? |
| Back to top |
GordoSD Tractor Guru
Joined: 09 Jun 2005 Posts: 6630 Location: Mitchell, SD
Posted: Wed May 30, 2012 5:50 am Post subject: Re: Allis Chalmers 444 Square Baler knotters |
Can you post some photo's? Perhaps take the assembly down to the IH store? |
| Back to top |
dubv Regular
Posted: Wed May 30, 2012 5:28 pm Post subject: Re: Allis Chalmers 444 Square Baler knotters |
I had the field mechanic from the CaseIH dealer out to look at it, he said it looked like a NH knotter but wasn't positive, the Agco dealer locally said Agco doesn't have a party number for it anymore. So, struck out so far. |
| Back to top |
Posted: Wed May 30, 2012 6:04 pm Post subject: Re: Allis Chalmers 444 Square Baler knotters |
The IH mech said he thought it looked like NH, so take the frame down to the dealer and have the parts man pull up the schematic for a few NH balers
As far as the billhook, I have one nos IH from a pair for a 275 and I only needed one. I'll get photo for you. Send me your cel phone number private and I message you a photo of it. |
| Back to top |
MoMike Regular
Posted: Thu May 31, 2012 9:38 am Post subject: Re: Allis Chalmers 444 Square Baler knotters |
You might Austins Salvage, Butler MO. Don't remember the phone offhand but he advertises on the AC website, not the one attached to YT. I bought a clutch pack complete for a 303 baler off of him this spring and he has a bunch of parts. |
| Back to top |
JDseller Tractor Guru
Joined: 09 Jul 2010 Posts: 4483 Location: North-East Iowa
Posted: Fri Jun 01, 2012 6:46 am Post subject: Re: Allis Chalmers 444 Square Baler knotters |
The the JD knotter is their own so I doubt that it is the same. The NH 315 baler is much newer than his AC 444 so I really doubt it is the same either. Many knotters look about the same because they have to do the same thing. Tie a knot. I don't know of any company that bought just the knotter assembly off of another company. Some whole balers where just painted different colors but not just the knotters. |
| Back to top |
morgan in ar Regular
Posted: Sat Jun 02, 2012 5:56 am Post subject: Re: Allis Chalmers 444 Square Baler knotters |
I've seen ac balers with deere knotter parts on them. I've got a ford baler with some new holland parts on it. Most knotters other than early massey and ih are VERY similar. The knotter frames may be a different story. You may be able to get the frame welded. I would then check out some billhooks at the deere or nh dealers if you can find somebody with the time to help you.-Morgan |
| Back to top |
Posted: Sat Jun 02, 2012 6:01 am Post subject: Re: Allis Chalmers 444 Square Baler knotters |
also, I think the 273 nh would be in the same time frame, but I'm pretty sure that they all use the same billhooks. |
| Back to top |
dubv Regular
Posted: Tue Jun 12, 2012 7:06 am Post subject: Re: Allis Chalmers 444 Square Baler knotters |
Thanks, I gave them a call today..sounds promising, I just need to get the casting number off my broken parts for them.
| MoMike wrote: | | (quoted from post at 18:38:34 05/31/12) You might Austins Salvage, Butler MO. Don't remember the phone offhand but he advertises on the AC website, not the one attached to YT. I bought a clutch pack complete for a 303 baler off of him this spring and he has a bunch of parts. |
| Back to top |
dubv Regular
Posted: Mon Jun 18, 2012 10:13 am Post subject: Re: Allis Chalmers 444 Square Baler knotters |
Here are a couple pictures of knotters on a 444 (not mine but a parts baler...unfortunately with broken knotters). I"ve tried numerous salvage yards I found listed on the AC boards, Agco parts dealer, CaseIH/NH dealer. If anyone out there has a knotter frame and a billhook for the Allis 444 square baler, let me know!
The frame has a stamp of RS 3770 on it if that helps.
| Back to top |
georgeky Tractor Expert
Posted: Wed Dec 19, 2012 10:50 pm Post subject: Re: Allis Chalmers 444 Square Baler knotters |
[quote="JDseller"](reply to post at 07:46:26 06/01/12) [/quote] nearly all balers incuding the jd,nh, and ac use mccormick knotters parts for the ac knotters are the same and can be bought at any new holland dealer. been getting knotter parts for my ac443 and ford 530 from new holland dealer for years.tell them you want parts for 68 hayliner. they will fit and work correctly if adjusted correctly. |
| Back to top |
