Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
deckover low profile trailers
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting
D beatty
PostPosted: Tue May 29, 2012 9:50 pm    Post subject: deckover low profile trailers Reply to specific post Reply with quote
I'am looking to buy a 14,000lb. bumper pull low profile deckover with 20ft.deck and a 3 ft. beaver tail.I have kind of narrowed it down to Liberty Trailer, PJ trailer or a Johnson Trailer( known as Roadwarrior). These trailers are built alike and in about the same price range. I'am looking for input from owners of these trailers good or bad. Thanks
Butch -Ia
PostPosted: Wed May 30, 2012 4:03 am    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
I had a PJ 20ft bumper pull before I got my gooseneck and it was a good trailer and pulled easy, Just not big enough. If you need it get the third ramp if you can.
Mike M
PostPosted: Wed May 30, 2012 4:19 am    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
That 3 ft. tail sounds kinda short ? ours had a 5 ft. you don't want them any steeper then needed.
Ralph Bauer
PostPosted: Wed May 30, 2012 11:46 am    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
even on a low profile, 3 ft dove/beaver is too short, 4ft+ at a minimum, 5' is better.
Just curious, but wouldn't it be better (for your circumstances) to look at a gooseneck trailer?
d beatty
PostPosted: Wed May 30, 2012 4:06 pm    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
On the low profile Liberty and PJ trailers the 3 foot beaver is standard equipment. The Johnson trailer uses a 4 foot but trailer set a little bit higher than the other two.I have seen a Liberty low profile setting next to a standard height trailer and if you put the ramps down on both off them there is very little differance in the pitch of climb to get on trailer. I'm going with bumper because it would be easier to move around the place if the truck is not available. Also if I would break down on the road all my freind are running bumper pull so I would have no trouble getting somebody to get trailer home.
bobs old iron
PostPosted: Thu May 31, 2012 11:08 am    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
i have a MAY CO trailer that has run-over wheel-wells, can hold 3k, not a real low profile, has 3 ft dove, but have ramps to make up the 6ft needed for loading, only because of low deck..
FC Andy
PostPosted: Thu May 31, 2012 2:43 pm    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
Question: How well does that adapter from gooseneck to fifth- wheel work? Does that eliminate some of the tippy- motion of the trailer when you hit a bump?
cd1
PostPosted: Fri Jun 01, 2012 5:20 am    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
check out the PJ Buggy Hauler. It is not 14K but it is a about as low as you can get and still have full 102" wide and 20' long. I have one, I like it for most things.
George Marsh
PostPosted: Sat Jun 02, 2012 6:10 am    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
I would avoid buying any trailer with a ramp that looks like this one. They tend to kick up when you put a load on them. The knee support should be in front of the pivot not behind. I had to modify mine. Just my $.02.
bobs old iron
PostPosted: Sat Jun 02, 2012 10:41 am    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
FC ANDY:::most of the goose neck trailers that have the round tube connectors, that hold the coupler in, can be removed and insert the fifth wheel pin tube in,,i hook it up to my 5th wheel set-up and it pulls and ride o-k...
mkirsch
PostPosted: Tue Jun 05, 2012 7:07 am    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
With a fifth wheel, all that "tippy motion" turns into frame twist.
Meangreen
PostPosted: Thu Jun 07, 2012 7:57 am    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
Take a look at this guy. Might find something that works better.
http://sltrailers.com/
44 massey
PostPosted: Thu Jun 07, 2012 1:57 pm    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
I have an 18ft 7000lb PJ and really like it. Pulls very nice loaded and empty tho wish it was a 14000. It seems well built.
1 Dollar
PostPosted: Fri Jun 08, 2012 12:43 pm    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
Here's a 32+4 low profile gooseneck. On a deckover low pro I would want no less than a 4 foot dove.
BarryfromIA
PostPosted: Sun Jun 10, 2012 6:30 pm    Post subject: Re: deckover low profile trailers Reply to specific post Reply with quote
I have a 20ft PJ B5 10000#. I pull it with a 3/4 ton Dodge and like it. Mine has 2ft dove tail and I can load a tractor off a good size hump in the yard with no ramps. The B5 and B6 trailers have drive over fenders.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
