| Author |
Message |
Bill Copeland Regular
Posted: Thu May 31, 2012 8:13 am Post subject: Fairbanks Morse 3 HP Model Z Ignition |
Has anyone converted this engine from magneto fired to points ,coil and condenser ? I think all I need is a set of points to open from the same pin that trips the lever on the magneto. It would take some fiddling to get the timing right. |
| Back to top |
Arnold Layne Regular
Posted: Thu May 31, 2012 8:05 pm Post subject: Re: Fairbanks Morse 3 HP Model Z Ignition |
It has been done thousands of times in the old days, now it would be kind of a step down unless you just plain can't get a good mag. Usually does involve some sort of contacts for points, buzz coils work real nice too. |
| Back to top |
hillbillybill New User
Posted: Wed Jun 06, 2012 8:39 pm Post subject: Re: Fairbanks Morse 3 HP Model Z Ignition |
my answer on your magneto remove the covers from the magneto remove the wires from the bottom of the points do not change point setting use 6 or 12 volt coil negative wire goes to bottom of points where you removed the old wires take a condenser from 8n ford connecting condenser wire with negative coil wire at the points plus wire from coil goes to 6 or 12 volt battery ground wire from battery connected to the engine or magneto box i have 3 of them running like that hope this helps |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
