Ford Detxa Oil pressure sending unit?
Gene Stephens
PostPosted: Sat Jun 02, 2012 6:39 pm    Post subject: Ford Detxa Oil pressure sending unit? Reply to specific post Reply with quote
My tractor does not have the oil pressure warning light on the column nor can I find a sending unit on the engine. Can someone tell me where the unit is or should be and what it looks like. A picture would be helpful.
Gene
El Toro
PostPosted: Sun Jun 03, 2012 2:46 am    Post subject: Re: Ford Detxa Oil pressure sending unit? Reply to specific post Reply with quote
Do you have a pressure gauge? It should have the gauge or or the light. Hal
Gene Stephens
PostPosted: Sun Jun 03, 2012 4:06 am    Post subject: Re: Ford Detxa Oil pressure sending unit? Reply to specific post Reply with quote
NO, I do not have a pressure guage. i understand it should have a warning light on the column underneath the steering wheel along with heat guage and charging light.
Gene
El Toro
PostPosted: Sun Jun 03, 2012 5:50 am    Post subject: Re: Ford Detxa Oil pressure sending unit? Reply to specific post Reply with quote
You should place your request over on the Ford forum. You will get more responses over there. Hal
Bob from Australia
PostPosted: Thu Jun 07, 2012 10:05 pm    Post subject: Re: Ford Detxa Oil pressure sending unit? Reply to specific post Reply with quote
I think Ford Dexta had Perkins 3 cylinder diesel.
If so, the sender unit is screwed into the block, to the rear, on the left hand side, more or less under the fuel filters.
