| Author |
Message |
Don656 Regular
Posted: Mon Jun 11, 2012 9:29 am Post subject: paint for exhaust manifold |
Is there any paint that will hold up on an exhaust manifold? |
| Back to top |
DScott Long Time User
Joined: 19 Sep 2002 Posts: 688 Location: White House, Tennessee
Posted: Mon Jun 11, 2012 11:37 am Post subject: Re: paint for exhaust manifold |
Don, It's been my experience that if it's a "show" tractor then the hi temp paints will probably hold up pretty good. If it's a working tractor then even the hi temp paint will not last very long. I have painted some on a couple of my tractors that are only ran at shows and they still look great after several years. I have a JD Model A with a manifold and pipe that has been ceramic coated and it looks like new even after plowing and working it pretty hard. |
| Back to top |
Don656 Regular
Posted: Mon Jun 11, 2012 1:06 pm Post subject: Re: paint for exhaust manifold |
When you painted with the hi-temp paint, did you use a primer first? Also, what brand of paint did you use? Is the ceramic coat expensive? |
| Back to top |
Eric in CA Regular
Posted: Mon Jun 11, 2012 2:00 pm Post subject: Re: paint for exhaust manifold |
I looked at the temperature ratings on some hi-temp paints and decided to try stove paint. Unfortunately it only comes in various shades of black or gray. I havn"t put it to work yet though. |
| Back to top |
Posted: Mon Jun 11, 2012 3:18 pm Post subject: Re: paint for exhaust manifold |
| don656 wrote: | | (quoted from post at 14:06:11 06/11/12) When you painted with the hi-temp paint, did you use a primer first? Also, what brand of paint did you use? Is the ceramic coat expensive? |
No, I do not prime them, I am not aware of any Hi temp primer. I do treat the manifold with phosphoric acid before painting to "kill" any rust that may be hidden away in the pores of the casting. That seems to help a lot to keep the rust from coming back. I them paint them with JD black muffler paint.
Works for me. |
| Back to top |
GlenIdaho Tractor Expert
Posted: Mon Jun 11, 2012 8:45 pm Post subject: Re: paint for exhaust manifold |
If you don't care about original a product called "Cast Blast" works very well. Sandblast the manifold and then paint. See link below for phots and link to source for paint.
Untitled URL Link
| Back to top |
Don656 Regular
Posted: Tue Jun 12, 2012 6:29 am Post subject: Re: paint for exhaust manifold |
That 850 looks really nice! Thanks for the tip, I think I'll try the cast blast. |
| Back to top |
Don656 Regular
Posted: Tue Jun 12, 2012 7:44 am Post subject: Re: paint for exhaust manifold |
On the cast blast site it says the paint withstands temperatures up to 1200 degrees. You can find hi-temp paint at most any auto store that also claims to withstand temperatures to 1200 degrees. So, that begs the question, is the cast blast any better than these paints? |
| Back to top |
GordoSD Tractor Guru
Joined: 09 Jun 2005 Posts: 6635 Location: Mitchell, SD
Posted: Tue Jun 12, 2012 3:51 pm Post subject: Re: paint for exhaust manifold |
Here's my H with the dast blast. Holds up perfectly
| Back to top |
Tony W Guest
Posted: Sun Jun 17, 2012 4:10 am Post subject: Re: paint for exhaust manifold |
I have good luck with even wood stove paint. for the black look. |
| Back to top |
Damon K. Regular
Posted: Mon Jun 25, 2012 1:23 pm Post subject: Re: paint for exhaust manifold |
Eastwood brand hi temp "Factory Grey" is made just for exhaust manifolds and works very well and does not burn off. Comes in pint can or aerosol. It does also come in satin black, silver or stainless steel. The factory grey looks most original like "cast iron" |
| Back to top |
thebigyellowtruck Regular
Posted: Tue Jul 03, 2012 9:31 am Post subject: Re: paint for exhaust manifold |
check out oreilly auto parts. they have a hi temp primer thats good for up to 2000 degrees and then many different high temp colors to top coat with.
hi temp paint. (2000 degrees)
http://www.oreillyauto.com/site/c/search/Paint+-+High+Heat/N0797/C0171.oap?keyword=hi+temp+paint&brand=VHT+Paint
hi temp primer
| Back to top |
CFR Regular
Posted: Tue Jul 03, 2012 9:52 am Post subject: Re: paint for exhaust manifold |
I used the VHT paint like you linked to on our M. Used PPC Phix (Link Below) as a primer. Haven't looked up under the hood yet to see how it's holding up, I will the next time I am around the tractor and report back.
I will say one thing, I used the VHT black, and the paint is VERY thin, and there is not alot of pigment in it.
http://www.ppcbest.com/phix_treatment.htm |
| Back to top |
Posted: Tue Jul 03, 2012 10:00 am Post subject: Re: paint for exhaust manifold |
i used the orange on an AC WD manifold and i liked
how it turned out, but because of colder spots on
the manifold the paint didnt bake to the same color.
no rust after 6 months though. |
| Back to top |
