Case 310 sprocket socket
Steve Hartwig
PostPosted: Tue Jun 12, 2012 3:59 pm    Post subject: Case 310 sprocket socket Reply to specific post Reply with quote
Will this be strong enough? Should weld right in. Should a keyway be cut into it?
AJ.
PostPosted: Fri Jun 15, 2012 6:25 am    Post subject: Re: Case 310 sprocket socket Reply to specific post Reply with quote
I would weld them straight in, watch out for shrinkage,if you have a spare shaft it would be a good idea to have it in the new hub when you weld it in.
AJ
Larry H
PostPosted: Mon Aug 13, 2012 6:33 pm    Post subject: Re: Case 310 sprocket socket Reply to specific post Reply with quote
Hi I need to do the same thing. I have the machining capability but have been unable to find the sockets can you tell me where you found then. Thanks
mike buchala
PostPosted: Thu Aug 30, 2012 3:12 pm    Post subject: Re: Case 310 sprocket socket Reply to specific post Reply with quote
I also would like to do this repair. Are these splined couplers ? were did you get them? any help would be greatly appriciated.
Steve Hartwig
PostPosted: Thu Aug 30, 2012 6:18 pm    Post subject: Re: Case 310 sprocket socket Reply to specific post Reply with quote
Well I had a machinist make them. He bored out the old splines and pressed the sockets in. They still need to be welded in place. Machinery spare parts, is the buisness and Dan Renfrow is the man. He did four sprockets and four sockets for 1000.00. His phone is 816-254-5156.
