D6c
navyreteocs
PostPosted: Thu Jun 21, 2012 1:57 pm    Post subject: D6c Reply to specific post Reply with quote
I ask before cant rember what was said . we have this D6 that quits pushing it will move very slowly . this happens about a hour you start pushing dirt after say 45 min its good for another 45 min to a hour of pushing . we thought the tranny (Power Shift)was getting hot install new temp gauge to tranny nope not hot . HELP
NCWayne
PostPosted: Thu Jun 21, 2012 8:01 pm    Post subject: Re: D6c Reply to specific post Reply with quote
If I remember correctly on a 6C there whould be a suction screen for the transmission pump under the floor boards right about where your left foot would rest. You'll probably have to pull the floor pan to get to it but you should see a vertical canister with a square top and botton with a cover held down by 4 bolts or studs and nuts. Remove the 4 bolts or nuts, insuring you don't drop the spring between it and the filter screen. Pull the screen from the housing and seperate the magnetic rings from the filter and clean both items.
No guarantees but this might fix your problem. Anything beyond that will indicate excessive wear in the clutch packs that will require going into the transmission to repair. Good luck.
