Gvi LP only runs with choke on
Pmer
PostPosted: Thu Jul 05, 2012 7:43 pm    Post subject: Gvi LP only runs with choke on Reply to specific post Reply with quote
I'm wondering what to look at in the LP system. What I did was swap starters and took off the regulator and carb together.
It has the Ensign system and I don't see anything obvious like broken lines or hoses. It sounds OK at idle but dies when choke opens.
The starter spins the engine good now though. LOL
Curt Cooke
PostPosted: Mon Jul 09, 2012 7:13 am    Post subject: Re: Gvi LP only runs with choke on Reply to specific post Reply with quote
pmer, about the only thing you can do is put the vaporizer on your work bench, replace LP supplu with compressed air and go through the tests outlined in an IT shop manual. The carburetor, once again, adjustments according to the book, there are no real moving parts.
CC
Pmer
PostPosted: Mon Jul 09, 2012 8:49 pm    Post subject: Re: Gvi LP only runs with choke on Reply to specific post Reply with quote
Thanks CC I found that the vacuum hose that goes from carb to regulator was bad and replacing did the trick.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
