tractor-ette 3 wheel mini tractor anyone know about these?
Joe Skittino
PostPosted: Sun Jul 08, 2012 1:35 pm    Post subject: tractor-ette 3 wheel mini tractor anyone know about these? Reply to specific post Reply with quote
I just bought a Farm-Ette mini tractor at a farm auction from the original owner. I cant find any info, pictures, ads, other ones on all of the internet! The guy said It is a 1944 or 1945. On the fuel tank it says Tractor-ette. Garden Tractor Manufacturing Co. Chicago Illinois. It has a Briggs BR6 engine, Borg Warner t96-1 transmission and unknown 10 bolt rear axle/ differential. 5.50x 16 Firestone ground grip rear tires and single front size 4.00-8. The entire unit is way over built with a steel I beam bent in a loop to make the frame etc. If anyone has any info and especially an original picture or ad I need your help to be able to re mount the seat at the original height and way the factory did it, because my seat just came as a loose piece. Thanks
ShadetreeRet
PostPosted: Sun Jul 08, 2012 8:40 pm    Post subject: Re: tractor-ette 3 wheel mini tractor anyone know about t... Reply to specific post Reply with quote
Google "Farm-ette garden tractor" it will give you several links that may help, and good luck.
jcwildwood
PostPosted: Sun Jul 29, 2012 12:27 pm    Post subject: Re: tractor-ette 3 wheel mini tractor anyone know about thes Reply to specific post Reply with quote
Joe Skittino wrote:
(quoted from post at 14:35:37 07/08/12) I just bought a Tractor-Ette mini tractor at a farm auction from the original owner. I cant find any info, pictures, ads, other ones on all of the internet! The guy said It is a 1944. On the fuel tank it says Tractor-ette. Garden Tractor Manufacturing Co. Chicago Illinois. It has a Briggs BR6 engine, Borg Warner t96-1 transmission and unknown 10 bolt rear axle/ differential. 5.50x 16 Firestone ground grip rear tires and single front size 4.00-8. The entire unit is way over built with a steel I beam bent in a loop to make the frame etc. If anyone has any info and especially an original picture or ad I need your help to be able to re mount the seat at the original height and way the factory did it, because my seat just came as a loose piece. Thanks
Post new topic    Yesterday's Tractors Forum Index -> Lesser Known Classics All times are GMT - 8 Hours
