| Author |
Message |
A DeWitt New User
Posted: Mon Jul 16, 2012 3:06 pm Post subject: Best kind of oil?? |
Just wondering if there is anyone out there running something other then 30 wt non detergent oil, I was thinking about maybe 15w40? The tractor is a 1948 Massey Harris 22 |
| Back to top |
JRSutton Tractor Expert
Posted: Mon Jul 16, 2012 3:25 pm Post subject: Re: Best kind of oil?? |
Unless the engine has recently been rebuilt, I wouldn't hesitate to go to 40, especially during the warmer months.
It should give you better compression and coat worn parts better - and increase oil pressure if your pump is getting worn. |
| Back to top |
A DeWitt New User
Posted: Mon Jul 16, 2012 4:30 pm Post subject: Re: Best kind of oil?? |
So switching from 30 wt to the 15w40 should help the engine then? I just wasn't sure about going from non detergent oil to regular detergent oil. |
| Back to top |
greygoat Tractor Expert
Posted: Tue Jul 17, 2012 4:59 am Post subject: Re: Best kind of oil?? |
Use Non-Detergent if you want sludge in your
engine ! |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50434 Location: Lake of the Ozarks area of MO
Posted: Tue Jul 17, 2012 7:28 am Post subject: Re: Best kind of oil?? |
Another one of those myths that say if you run non-detergent oil you can not switch or it will clog things up. Ya it may break a bit of it down but the filter will catch it and be goner in one or 2 oil changes |
| Back to top |
ASEguy Tractor Expert
Posted: Tue Jul 17, 2012 11:43 am Post subject: Re: Best kind of oil?? |
Run detergent oil. The weight depends on the temperature where you are and the oil pressure of the engine. Most engine wear occurs at start-up so a multigrade would be fine. |
| Back to top |
El Toro Tractor Guru
Posted: Tue Jul 17, 2012 11:48 am Post subject: Re: Best kind of oil?? |
I use 30wt detergent oil in all my garden tractors and mowers. My garden tractor is 42 years old and the engine has never been rebuilt. It's used hard when plowing the garden Spring and Fall. Hal
| Back to top |
rustyfarmall Tractor Guru
Joined: 07 Feb 2003 Posts: 18487 Location: Southwest Iowa
Posted: Tue Jul 17, 2012 1:32 pm Post subject: Re: Best kind of oil?? |
| A DeWitt wrote: | | (quoted from post at 16:06:22 07/16/12) Just wondering if there is anyone out there running something other then 30 wt non detergent oil, I was thinking about maybe 15w40? The tractor is a 1948 Massey Harris 22 |
Very few, if any, folks still use the non-detergent 30 weight. 15w-40 seems to be the motor oil of choice anymore. |
| Back to top |
David G Tractor Guru
Posted: Tue Jul 17, 2012 5:45 pm Post subject: Re: Best kind of oil?? |
Nope, 15w-40 in everything. |
| Back to top |
Dean Olson Long Time User
Posted: Tue Jul 17, 2012 6:26 pm Post subject: Re: Best kind of oil?? |
I run Chevron Delo 15w-40 in everything . Grandad ran it, dad ran it, I run it.
I believe the myth that going from non detergent oil to detergent oil creating ANY problem is an old wives tale. This opinion is based on 3 generations working and playing with old tractors. |
| Back to top |
A DeWitt New User
Posted: Tue Jul 17, 2012 7:17 pm Post subject: Re: Best kind of oil?? |
I changed the oil and filter last night, I went with 15w40 and Lucas oil stabilizer. Oil psi is higher then it's ever been, thanks for all the great advice. Alex |
| Back to top |
Jerry/MT Tractor Guru
Joined: 22 Jul 2003 Posts: 9852 Location: Western Montana
Posted: Fri Jul 20, 2012 11:00 am Post subject: Re: Best kind of oil?? |
A lot depends on the temperatures you operate at. I live in Western Montana and we have three tractors, two diesels and a gasser. I tried using 15W40 in the gasser(only oneS AE Grade oil to buy for ag equipment and diesel pick up then) and I noted it was harder to turnover in the winter months so I went back to using 10W40 in it.if you live in a mild climate and use your tractor in the winter 15W40 will work for you. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23627 Location: in front of computer
Posted: Fri Jul 20, 2012 8:21 pm Post subject: Re: Best kind of oil?? |
Can't go wrong with Shell Rotella T1 straight weight. There are some things a monoweight can do that a multi-weight can't. |
| Back to top |
WGM Regular
Posted: Sun Jul 22, 2012 11:15 am Post subject: Re: Best kind of oil?? |
Only a fool would use non detergent oil in anything. |
| Back to top |
Howard H. Tractor Expert
Joined: 28 Feb 2002 Posts: 1792 Location: North Texas Panhandle/OK Panhandle
Posted: Thu Jul 26, 2012 7:49 am Post subject: Re: Best kind of oil?? |
I sure wouldn't agree with that statement.
Plenty of applications have guidelines that recommend a non-detergent oil, like air compressor pumps, lathe gearboxes, some hydraulic apps, etc...
A ton of manufacturers put out a lot of different kinds of non-detergent oil...
Howard
For example
| Back to top |
