| Author |
Message |
Ron Holcombe New User
Posted: Mon Jul 23, 2012 3:30 pm Post subject: WD-45 Hydralic pump |
I operated a WD-45 as a kid but don't remember much about it. When I engage the Hyd. the pump makes a loud knocking sound, is this normal? If not where do I begin to look? This a 55 model. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50397 Location: Lake of the Ozarks area of MO
Posted: Mon Jul 23, 2012 4:26 pm Post subject: Re: WD-45 Hydralic pump |
Only time my WD45 does that is when it is low on fluid so have you check to make sure your fluid level is as it should be???? |
| Back to top |
Posted: Tue Jul 24, 2012 6:59 am Post subject: Re: WD-45 Hydralic pump |
Yeah, the dip stick kept showing empty and I would add till it was showing full. But each time I would move the front loader the oil whould show empty again. I have added quiet a bit of oil to it now but it still knocks when engaged, besides some leaks should I start to consider a new pump? |
| Back to top |
old Tractor Guru
Posted: Tue Jul 24, 2012 10:50 am Post subject: Re: WD-45 Hydralic pump |
You need to start by finding out where all that fluid is going. Even if it is a bad pump if you loose that much fluid a new pump will not last long either find and fix the leaks then look at other thing. You may find that once you keep fluid in that the problem is no longer there |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
