| Author |
Message |
Roger in Iowa Long Time User
Posted: Mon Jul 23, 2012 7:08 pm Post subject: 440 JD crawler/loader engine removal |
Anyone have experience on removing the engine from a 440 crawler loader. Main clutch is stuck and housing is full of mouse nest.
Looks like it will be difficult to work around loader. |
| Back to top |
original possum Guest
Posted: Mon Jul 23, 2012 8:58 pm Post subject: Re: 440 JD crawler/loader engine removal |
Block the loader in the raised position with angle iron resting on the lift rams. Then start from the front. |
| Back to top |
Posted: Wed Jul 25, 2012 6:30 pm Post subject: Re: 440 JD crawler/loader engine removal |
Do I have to pull the hard nose/grill/hydraulic reservoir? Or is there enough room to pull the engine after removing the radiator? |
| Back to top |
Posted: Thu Aug 02, 2012 2:31 pm Post subject: Re: 440 JD crawler/loader engine removal |
It's been a long time, but I don't recall pulling off the nose. You do have to take the pump drive off the front of the engine. Whether you need to pull the pump depends on the type of drive. If you have to pull the pump you may as well pull the nose and replace the captive nuts that fasten the belly pan on. |
| Back to top |
730d se Tractor Expert
Posted: Wed Aug 15, 2012 3:48 pm Post subject: Re: 440 JD crawler/loader engine removal |
Is it gas (440 IC) or diesel (440 ICD)?
The gas has the pump made in the front of the engine. The diesel has a pump in front on the crankshaft. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
